6030 losing hydraulic 2 times same distance
francis pawelek
08-07-2007 20:00:27
yesterday we were testing an 18 foor crosscut on a 6030 jd i just restored,,,it went close to 1 mile pulling ,then steering went away,after it set over nite it was ready to go again,,,,well today the same thing happened ,,could it be the new hydraulic filter is not letting oil return fast enough?or could the filter be plugged up from a hydraulic system not being used 7 years?
i'm going to put in another filter in morning,i do have a new one on now,could a filter actually be stopped up thats not letting oil get to the remotes quik enough?tractor has plenty of hydraulic oil too,thanks
G/MAN
08-08-2007 07:31:28
 Re: 6030 losing hydraulic 2 times same distance in reply to francis pawelek, 08-07-2007 20:00:27
A new filter is not going to restrict oil flow. Sounds like a plugged sump screen to me. A big internal leak isn't too likely, especially if you weren't using a lot of the hydraulic system capacity - it takes a big one to dump all of the main pump output to the point where steering, which has priority, is affected. Much more likely that the sump screen is plugged and is starving the transmission pump, and therefore the main pump for oil. The distance you traveled is how long it takes for the screen to become sufficiently plugged to starve the system. Shut the tractor off, the material falls away and it will work normally until it plugs up again. And it's much easier to pull the screen than track down an internal leak.
francis pawelek
08-08-2007 11:09:25
 Re: 6030 losing hydraulic 2 times same distance in reply to G/MAN, 08-08-2007 07:31:28
thanks i'll pull that ,,,
MSM
08-07-2007 23:55:34
It could be the filter,but I would be more inclined to look for an internal hydraulic leak.An internal leak will heat and foam the oil to a point that the charge pump cannot maintain capacity to the front pump and you begin to lose functions. About 20-30 minutes running usually starts showing loss of function. It could be a bad rockshaft valve,one or both of the remotes,difflock valve,or pto valving. Start the tractor up cold and let it run for 15 minutes and go around and feel the remotes,look in the hyd.oil fill for an oil spray. If a valve is leaking it will heat up considerably more than the surrounding areas.
francis pawelek
08-08-2007 06:50:24
 Re: 6030 losing hydraulic 2 times same distance in reply to MSM, 08-07-2007 23:55:34
how do you track down a internal leak?also the last time my 7520 done this it had a dirty filter,i'm still going to swap filters,too much oil came out of housing when i turned it lose yeasterday,most tractors will lose 1 quart from there this baby lost 2 gallons at least sir,thanks for your help though
G/MAN
08-08-2007 07:33:10
 Re: 6030 losing hydraulic 2 times same distance in reply to francis pawelek, 08-08-2007 06:50:24
Do the simple stuff first - change the filters and sump screen. Looking for an internal leak should be quite a ways down the list when diagnosing an issue like this.
francis pawelek
08-08-2007 11:11:19
 Re: 6030 losing hydraulic 2 times same distance in reply to G/MAN, 08-08-2007 07:33:10
ok you got it sir i'll do it today
buickanddeere
08-08-2007 07:30:19
Put a pressure gauge on the transmission test port. Another gauge on the front pump outlet. Otherwise we are just guessing and throwing parts randomly at the tractor hoping to solve the problem. The gauge(s) may indicate surging, fluttering or a gradual loss of charge pressure. What all did you have apart and what was worked on? Is there air getting drawn into a pump inlet? The transmission relief valve/pressure control circuit can fail and either drive pressure too high or too low. If the trans/hydraulic oil looks grungy, it is.
francis pawelek
08-08-2007 11:14:28
 Re: 6030 losing hydraulic 2 times same distance in reply to buickanddeere, 08-08-2007 07:30:19
sir i rescued this old 77 6030 from setting in a field with a camshaft with no teeth,i completely rebuilt it totally,ground up,but didnt mess with the hydraulic area but change the filter,its gotta be that screen ,i was just loooking on my 7520 side and 8630 but the 6030 is on the oppositre side i hear now,it sat 7 years
Bob
08-07-2007 21:21:13
Have you checked to see how much material from your brake linings is sucked against the transmission pump sump screen???
francis pawelek
08-08-2007 06:47:51
 Re: 6030 losing hydraulic 2 times same distance in reply to Bob, 08-07-2007 21:21:13
well instead of a square fitting like my 7520 has,,,i see a freeze plup in its place ,where exactly is that plug you are telling me about?in front of left axle?
Bob
08-08-2007 06:53:01
 Re: 6030 losing hydraulic 2 times same distance in reply to francis pawelek, 08-08-2007 06:47:51
jdparts shows the screen behind a square-headed plug, apparently on the RIGHT side.
Third Party Image
francis pawelek
08-08-2007 11:03:05
 Re: 6030 losing hydraulic 2 times same distance in reply to Bob, 08-08-2007 06:53:01
woops ,,,,wrong side ,i guess i only suspected the left side i'll suure look,thanks pal
what is a mint 6030 w/ new engine worth these days?
