DLTX 67 Questions
Brent in WI
08-07-2007 19:33:54
Hello, I'm rebuilding my B carb and have a couple of questions that I could not find answers to in the SM 2000 manual for rebuilding these.
1. Float bearing screws - Are there no gaskets for these? The parts book shows none so I'm assuming the sealing is done by the soft brass heads of the screws to the sealing surface of the float body? What confused me is I have a parts carb that had o-rings for gaskets and the one off the tractor had none.
2. Two different thickness main carb body gaskets - Which one goes up-stream and which one goes down-stream or does it matter? I didn't realize there was a difference until I was looking at the rebuild kit.
Thanks Much
Mike M
08-08-2007 05:04:18
 Re: DLTX 67 Questions in reply to Brent in WI, 08-07-2007 19:33:54
On those float pin bearing screws I highly recommend putting a trace of non hardening permatex on the underside of the heads of them to help them seal.
also do the same to the threads of the brass screw passage plugs
wilamayb
08-07-2007 19:56:14
Those float bearing screws shouldnt have any type of gaskets under them, but seems as though reusing them time after time yields a seeping carb. Most have been overtorqued and used time and time again the until the head has become distorted. If the gaskets work I say "why not?" although I wouldnt think new screws would be too terribly expensive.
As for the gaskets..... .. The thick one goes between the intake manifold and carb and the thinner goes between the air breather and carb.
Glad to see a man on here with the proper manuals. A good manual just makes you feel smart does'nt it?
