JD A and B Wide Front Casting
40 JD G
08-07-2007 16:45:42
Does anyone know if the casting number is the same for the A's and B's on the early styled wide fronts. Also is there much appearance difference from these compared to the unstyled wide fronts. Thanks
Bob Gauntt
08-07-2007 20:45:55
 Re: JD A and B Wide Front Casting in reply to 40 JD G, 08-07-2007 16:45:42
The pedestals on the Unstyled and Early Styled JD AW and BW tractors are all different castings, however they all shared the same A1100R axle. The AWH and BWH tractors shared a different axle that was designed to use bolt on extensions.
