A troubles
cash
08-06-2007 23:19:43
My A used to starts an idle fine . When the govenor would open up under load it would die some times. Lately It quite and i cannot get it to run. It appears like it floods the LH cylinder while the RH is dry how ever if it fires it is on the flooded side. It has 45-48lb compression and I have changed carbs and mags, I am wondering if any one has had mag problems like this or any ideas?
Mike M
08-07-2007 05:27:11
 Re: A troubles in reply to cash, 08-06-2007 23:19:43
That compression is VERY low. Are you testing it with a good gauge and at wide open throttle so it can get good air ?
cash
08-07-2007 05:36:32
 Re: A troubles in reply to Mike M, 08-07-2007 05:27:11
not sure about wide open throttle, Ill retry. Do you know about what it should be?
Mike M
08-07-2007 05:47:31
 Re: A troubles in reply to cash, 08-07-2007 05:36:32
If it has all-fuel pistons 65-75 lbs psi would be good if it has GAS pistons then you should be upwards of 100-125 lbs psi
GeorgiaHayFarmer
08-07-2007 04:03:31
Howdy,
Tell us what year A you have there. You can check a mag for fire by pulling the wires and putting a known good plug in to check for a hot blue strong spark bump the starter over so you know the mag impulse is doing what it should do at idle. Put new plugs in to eliminate any questions along that line. They may be fuel fowled. It is very hard to look at a plug and tell if it is fuel fowled sometimes and they will drive you crazy.
Your carbs...
If they are not completely clean and repaired correctly and you have a clogged idle circuit then it's not gonna want to idle just right. Have you got good fuel in the tank? Is your air cleaner free of cloggs or stopped up? If you have any kind of flooding going on then be sure to check your oil for contamination. It will be very thin and smell like fuel. Sometimes the flooding gas will get in the crankcase and you don't want to run a tractor that you like on oil thinned with fuel...
Check your governor to throttle linkage for proper adjustment every time you remove and install a carb on a tractor, like your A. It can make a difference.
Regards,
Scott
cash
08-07-2007 05:42:33
 Re: A troubles in reply to GeorgiaHayFarmer, 08-07-2007 04:03:31
Not sure of the year, but it is late model styled. I had but in a new set of plugs but ill get another new set. The mag spark isnt real strong but it is blue. Impulse is working great. I know fuel circuits are clear and fuel is fresh.
Roy in georgia
08-07-2007 19:04:12
 Re: A troubles in reply to cash, 08-07-2007 05:42:33
I bought 4 new deere plugs the other day for my 1010 and one was bad caused me to say a few things when I spent 2 hours trying to find out why a tune up and carb. rebuild didn't help it run better
