3020 aftermarket load and depth seals
jd40203020
08-06-2007 20:31:45
On my 3020, the JD load and depth seals cracked again after only 2 years, so I decided to try the ones from Boling Machine. I replaced the seals and the shaft, with their o rings and their shaft. As soon as I used the tractor the selas leaked bad. I called them back and they sent me another set. before I put them in, I measued the shaft to be sure it was the right one, used silicone in the housing, and was extra careful to oil the shaft and push it in gently. These ones leak without moving the tractor. Is there something I am missing or doing wrong? The shaft fits snug, but is easily slid in the seals. My only explanation is that some how I got the o rings from a 4020. which does have a bigger shaft? Any ideas??? I am going to call them back tomorrow, but thought I would ask for some help here first to see if I missed something.
diskin
08-09-2007 14:50:12
 Re: 3020 aftermarket load and depth seals in reply to jd40203020, 08-06-2007 20:31:45
I am currently doing mine on a 3010. I am having trouble getting the inner bushings(trans housing) out . Sounds like heating is the way to get them out? I have not been able to knock them out from the back side as I can't catch enough of the lip on the inside. I am using aftermarket bushings with inner rubberseal. This is the third time for this repair and the last time it was done by a former JD tech. It seems to be a design flaw?
Mike M
08-10-2007 05:33:15
 Re: 3020 aftermarket load and depth seals in reply to diskin, 08-09-2007 14:50:12
I think I used an old shaft with one end cut off square to drive them out.
diskin
08-12-2007 12:30:39
 Re: 3020 aftermarket load and depth seals in reply to Mike M, 08-10-2007 05:33:15
Mike- Thanks for the old shaft tip- Worked like champ
TimS in Mo
08-12-2007 21:53:05
 Re: 3020 aftermarket load and depth seals in reply to diskin, 08-12-2007 12:30:39
You can also use an inside type puller setup to grab the inner lip of those bushings in the transmission housing, then use a shaft of some sort to tap on the puller arms to ease that bushing out...
Definitley change the bushings in the yoke as well as the trans housing, also get the shims from deere to take any side to side play out as well, those shims go between the yoke and the trans housing.
diskin
08-13-2007 14:14:06
 Re: 3020 aftermarket load and depth seals in reply to TimS in Mo, 08-12-2007 21:53:05
Tim- Are yolk bushings really thin compared to trans bushings? My 3010 doesn"t feel like it has any. There is a small inset in yolk for shims,I assume. No manuals show yolk bushings that I have or have read about. I"ll ask my neighbor who is a JD tech. Thanks for input -I need all I can get as I"m tired of watching that high $ fluid leak out.
Mike M
08-07-2007 05:43:10
Oh no here we go again !!!! Some swear at them and some swear by them !
I personally would not do another one without those aftermarket bushings with the o-ring as the ones I have done have worked very well.
The part you should be getting from Boling is the bushing that goes in the case with an o-ring added to it for extra sealing help. They need to fit tight in the case a slight press fit if not you need oversized ones. There is a taper on the insides of them and it needs to go a certain way you should of gotten an instruction sheet with them. You also still use the OEM seals that fit in the outer step in the case. The bushings in the drawbar frame/3pt support and the use of shims to tighten it up and remove all side play will add to the longevity of the repair. I don't think I'd be using silicone sealer in there either. Something like loctite ? may be better as to keep them tight. Are you leaking around the shaft or the bushing to the case area ? I suspect maybe the later ?
Jd40203020
08-07-2007 21:48:13
 Re: 3020 aftermarket load and depth seals in reply to Mike M, 08-07-2007 05:43:10
They are leaking around the shaft. Definately don't need locktite! It takes a big hammer to get them in, and the don't come out unlss they are heated then cooled. I am getting the cut bushings with the o rings in them, and they fit in where the JD seals would have been. There is no place to put the JD seal in them with these. I am guesing I need to replace the JD wear bushings in the case to make these seal up then. I hope! One more try then I am going back to JD seals!
Mike M
08-08-2007 05:21:19
 Re: 3020 aftermarket load and depth seals in reply to Jd40203020, 08-07-2007 21:48:13
What serial number 3020 ? I wonder if you are getting the right stuff from them ? So far it sounds totally different than what I worked on, but mine were early models, is yours a late model ?
They seem different now ?
08-08-2007 05:32:38
 Re: 3020 aftermarket load and depth seals in reply to Mike M, 08-08-2007 05:21:19
I just found their web site and what they have pictured on there doesn't look like anything I used before from them. Maybe this is the problem now ? I saw some on ebay that looked like what I had used before. Mine were just the bushing up in the case with an o-ring installed in them and then you could still use the original type outside seal from Deere too.
Jd 40203020
08-09-2007 21:42:16
 Re: 3020 aftermarket load and depth seals in reply to They seem different now ?, 08-08-2007 05:32:38
Must be they are different. There is no way to use the jd seal with these. And My 3020 is a 71 or 72 model. not sure of the serial # without looking at it. I know I have the right shaft because I measured it compared to the old one. Havent had time to tear back into it, but I will update this when I do. Thanks for all the help!
Bunghammer
08-06-2007 21:35:10
Yes there are bushings in the transmision housing and in the A arm also. I have found that it is usually the cause of the seal leaking. You can get those bushings out by using your old shaft, there is a small ledge in which you can pound on. I usually stick an old shaft in there a little to plug the hole. Then run a small weld bead around the bushing to shrink it. After that it will come right out. If you don't replace all the bushings I think you"ll have a hard time getting it to stop leaking. I"m sure there are a thousand ways to get it done, just my opinion. BC
JD 40203020
08-06-2007 20:39:00
Just thought of something else. Are there bushings inside the case that could be worn and makng these seals flex too far? They look like bushings to me, but I didn't dare to try to get them out.
