620 steering issues
Tech 7
08-06-2007 12:50:48
I am not winning at this job Original problem was front wheels shimmying at road speed. Worm shaft end play has been adjusted ...no change..removed inspection plug to check screw that rides in helix ..no screw..rotate steering shaft half turn,found pin..drove in slightly no more shimmy but steering shaft wants to bind. Any suggestions? Thanks, Bob
machinery-man
08-06-2007 17:30:57
 Re: 620 steering issues in reply to Tech 7, 08-06-2007 12:50:48
I've worked on a lot of these and I would suspect worn knee bushings in the rollamatic. This would allow walbing of the knees, this would translate up the shaft and you may think steering.
Mike M
08-06-2007 13:09:48
If you have no screw then you may have the "improved" design that is no improvement. It is adjustable up front of the worm. Very touchy ! Your going to have to pull it apart and possibly drive that pin back out you drove in. Good bet it's worn and needs replaced or turned. Make sure you also set the up and down play of the shaft in the front column.
Tech 7
08-06-2007 16:10:12
 Re: 620 steering issues in reply to Mike M, 08-06-2007 13:09:48
thanks Mike I hate looking for things that don't exist. Is the adjustment done on the front of the worm shaft with the nut/setscrew? When you say up/down movement I believe you mean on the pedestal shaft itself right? Right at the moment we have a lot of binding going either direction. Worked better before we started #$%^&&*!! Thanks again for your info, Bob
Mike M
08-06-2007 19:20:27
 Re: 620 steering issues in reply to Tech 7, 08-06-2007 16:10:12
Yes to both of those. Alot of experienced mechanics have alot of trouble getting those working so be fore warned. Do you have a factory JD service manual on these power steering units ? if not they are a must have.
You don't want them binding as it can be murder going down the road. Literally
