3020 Questions
MoMark
08-06-2007 06:06:16
Have a 3020 gas (yes it has the dreadful MS carb). It runs well enough but the hand throttle won"t hold position. Is there a place to adjust the "drag" for the throttle?
Another problem is the 3-pt control lever on the dash is stuck solid in the forward position. Is there a lock or something that I am missing or do I just have a linkage problem?
Thanks for any help.
Mark
MoMark
08-06-2007 10:14:49
 Re: 3020 Questions in reply to MoMark, 08-06-2007 06:06:16
Thanks guys, you have told me exactly what I needed to know. It's not my tractor, I'm just doing some work on it & trying to get everything in order.
G/MAN
08-06-2007 07:27:22
It's most likely a seized cable, but disconnect it at the rockshaft valve to make sure. A new cable is $115 or thereabouts and an hour or so of labor will replace it.
turklilley
08-06-2007 06:41:14
The 3-point is operated by a cable from the dash lever to the control below the seat. The cables rust up and get tight. They are a pain to free up, and expensive to replace.
Bob
08-06-2007 06:25:51
Third Party Image
The throttle friction pads are Key # 20. The nut to tighten the tension on them is Key # 24.
There are variations of the PTO linkage, depeneding upon transmission type and serial number. However, something rusted up is the most likely cause of the stuck PTO lever.
Bob
08-06-2007 06:43:12
 Re: 3020 Questions in reply to Bob, 08-06-2007 06:25:51
Sorry about that! I mangled your question about the 3-point into a PTO question!
