Do I have more trouble then I thought?
northeast pulle
08-05-2007 15:03:22
I am working on a 1949 G. What started out as a leak down test which was 96% in both cylinders cold and new valve springs and new manifold replacement may have turned ugly. I managed to get all the manifold bolts out with out any incidents but one. When I took the left rear bolt out (From the driver�s seat) I got a gusher of antifreeze. Is this normal or do I have a cracked head from somebody else�s � A!!!! work. The Head bolts are a � inch thru the manifold .Has some body tighten a too long bolt down or do I have other problems? I no that the bottom to head bolts have been run in to far and bottomed out and in the block and put hair line cracks in the casting causing slight waiter drip.
My plan for the winter is to die the system and see what else may be cracked. And repair all . Do I have head troubles as well? It may be time just to to tear it all a part and see what all as been F!@#@@#@ up by who ever else before I bought this monster.This all started chasing a miss under load and the float level is is good and the compression is 65 and 68 psi hot. Any in put is always welcome..
Lee B
08-05-2007 16:41:30
 Re: Do I have more trouble then I thought? in reply to northeast puller 1, 08-05-2007 15:03:22
I had a miss under load that turned out to be my magneto. It finally broke so I got a distributor and use that with a Pertronix 3 ohm coil and .080 spark plug gaps with NEVER a miss. I used to have to run with my right hand on the clutch because if she missed twice in a row, she was dead before I could unclutch it otherwise - talk about a miserable way to farm.
I don't have a G and no experiance with over length manifold bolts tightened too far on the G, sorry no help there. But I'm suspicious like you.
I also have done some chasing down of bad items on my A from a previous owner who if he has any brains would never show up here without a police escort, I can advise you that you may bite off more than you care to chew on and quite quickly at that. For example, I dumped $300 on block welding that didn't last worth a darn - I now rely on 4 large bottles of Bar's Leak, it's much cheaper too.
Bottom line - don't loose sight of the bigger picture. Just because the other guy was a real dummy is no reason for you to pour your good money down a sink hole just to try to do it up the right way. There is always another G around somewhere which might be a better starting point.
I just wanted a work tractor and now I have one so my wrench twirling is done for the most part.
