420 ps control valve leaks
Dave H
08-04-2007 19:42:14
Ihave the char lynn control valve on the steering shaft of a 58 420. I have been plagued with a leak on the front shaft area - around shaft.
I thought I had it knocked in that i did a repair with a juiffy sleeve and a snug O Ring. After running it naked for about 20 hours with no leaks I decided to put the sheet metal on. The tractor had been sitting about 2 to 3 months.
Started it up and found cherry juice on both sides of the motor. I am at witts end at trying to deal with this leak.
Any ideas like maybe a place to send the core, get to the bottom of the problem, whatever. I have been down this road 3 times now.
Thanks
David H
08-17-2007 20:25:30
 Re: 420 ps control valve leaks in reply to Dave H, 08-04-2007 19:42:14
I had the same problem on my father's 58 420. I fixed it by taking the valve housing apart and boring the end covers so that a seal could be pressed into the bore. This took the place of the o-ring which doesn't work very well. I did this repair a few years ago and don't recall the seal number that I used. You can purchase seals from a bearing supply house. A lot of them will have a catalog for Chicago Rawhide seals. In that catalog you can determine the size of seal that you can fit into each end cover. You then need to find someone with a lathe to bore a hole into each cover that the seal can be pressed into. The catalog should state what the dimensions of the hole should be. Hope this helps. It worked for me.
