JD 1020 WITH FUEL SHUT OFF SOLENIOD
SHORTORDER
08-04-2007 18:16:33
I have a JD 1020 tractor with a fuel shut off solenoid on a TSX904SL. The local JD Dealer wants right at two hunder dollars for the soleniod. I understand that there is away around the soleniod. Is there anyone out there that knows how it is done? I'm not a super mech so I need some good detail in the how it is done.
Shortorder
A
Doug in IL
08-06-2007 07:04:55
 Re: JD 1020 WITH FUEL SHUT OFF SOLENIOD in reply to SHORTORDER, 08-04-2007 18:16:33
The selenoid and valve that you have now are all in one piece. When you unscrew the selenoid, the old valve comes with it. If you get the new valve, it will be easy to see what to do.
msb
08-04-2007 19:42:17
Remove the spring inside it. You may have to idle the tractor longer to keep if from dieseling with the spring removed.
Doug in IL
08-04-2007 19:24:52
Do a search for "2020" in this John Deere forum. A recent discussion of this problem is on the second page that will come up.
SHORTORDER
08-06-2007 05:08:37
 Re: JD 1020 WITH FUEL SHUT OFF SOLENIOD in reply to Doug in IL, 08-04-2007 19:24:52
Doug in IL I read your input but still have a couple questions. Do you remove the old nozzle from the carburetor before put the new needle set in the carb? Is there a preset on the needle set to start with. Thanks for your input.
Doug in IL
08-06-2007 06:48:22
 Re: JD 1020 WITH FUEL SHUT OFF SOLENIOD in reply to SHORTORDER, 08-06-2007 05:08:37
Diconnect the wire on the selenoid from the wiring at the plug in for it. Unscrew the selenoid from the carb. There is a hex on the seleniod to use a wrench on. Screw the new valve into the carb and tighten it. Turn the stem in on the new valve until it bottoms out. Don't force it, do it gently. Then turn the stem back out a couple turns. The tractor should start. Adjust from there for the best running.
SHORTORDER
08-06-2007 07:03:15
 Re: JD 1020 WITH FUEL SHUT OFF SOLENIOD in reply to Doug in IL, 08-06-2007 06:48:22
Sounds simple enough. I more quick question. John Deere wants $65.00 dollars for the part and Roberts Carburetor $16.00. Something is not right here. Would you agree that more then likely the part from Roberts is not correct.
David Snipes
08-06-2007 12:20:23
 Re: JD 1020 WITH FUEL SHUT OFF SOLENIOD in reply to SHORTORDER, 08-06-2007 07:03:15
A friend of mine bought a non JD solenoid and it worked just fine in his 2020,
Doug in IL
08-06-2007 07:06:59
It's hard to say. But I do know the Deere part is the right one and works well.
