1010 trans fluid
Roy in georgia
08-04-2007 15:19:13
I have water in the fluid so I am draining it out any idea what fluid- gear oil to put back in? also hydraulic fluid type?
Jeff McBride
08-04-2007 15:57:32
 Re: 1010 trans fluid in reply to Roy in georgia, 08-04-2007 15:19:13
My manual says 90 wt and I think you are right on the bolt- clutch adjustment.
Roy in georgia
08-04-2007 16:01:22
 Re: 1010 trans fluid in reply to Jeff McBride, 08-04-2007 15:57:32
how about the hyd. fluid? My manual is M.I.A. so these things are hard to find out if it wasn't for all the helpful people on here. Thanks, Roy
Roy in georgia
08-04-2007 15:47:57
I also need to know how much to get. There is a nut with a bolt that has a flat tip on it located under the throwout bearing grease fitting cover is this to adjust the clutch?
buickanddeere
08-04-2007 22:15:48
 Re: 1010 trans fluid in reply to Roy in georgia, 08-04-2007 15:47:57
1-800-522-7448
Use GL-4 Marine in the transmission & finals. The Dubuques have copper metal in the transmissions the Waterloos didn't.
