Hyd. cyl repair
Wi Tom
08-04-2007 13:34:51
I need to rebuild the remote cylinder from my B tractor but John Deere can't get the parts anymore. Anyone have any ideas on who might have the parts I need??
Thanks
D Bear
08-04-2007 16:24:08
 Re: Hyd. cyl repair in reply to Wi Tom, 08-04-2007 13:34:51
WWW.Greenstore.org
Hayfarmer
08-04-2007 15:42:08
Is it the old style cylinder originally supplied with the tractor? What needs to be rebuilt? If just leaking around the rod, could just need to be tightened down, that is a chevron type packing on the end. I rebuilt an A cylinder a few years back and found the same problem. The Deere dealer happened to have a chevron packing that was the right size for the end. On the inside were some cups which seemed to be ok but the washer behind them wasn't, allowing too much flex. I cut a piece of leather from an old boot top and put behind each one. Has worked fine since then.
Gerald J.
08-04-2007 14:50:30
Probably mostly fat o-rings. Try Baum Hydraulics, www.baumhydraulics.com
Gerald J.
