J.D. 50 jumps gear
Brian Y.
08-04-2007 10:33:58
Guys, Hope someone out there might be able to help. I have an early model JD 50 that is soon to be a project. I do know that it would slowly work the shift lever out of 4th gear when walking downhill (hoding back). What are the problems that could be causing this? I would like to thoroughly go over this machine. Any help would be appreciated. Thank you!
2cylinderlp
08-04-2007 12:45:33
 Re: J.D. 50 jumps gear in reply to Brian Y., 08-04-2007 10:33:58
4th gear is outside the main case under a cover on the flywheel side. If you get the flywheel and that cover off, you can investigate in there. Drain the transmission first. It could be several things. In general I would look for things that allow the gear to misalign slightly in some way with shaft it runs on, or the the other gear it meshes with. Things like bearing wear, wear in the splined hub of the gear or on the shaft might be the problem. A weak or broken shifter pawl spring may also be a factor. A bent or worn shifter fork could be a factor. It's a bit of a challenge if you haven't done one before. But if you think you are up for it, I would get a manual and do a complete disassembly of the transmission. Clean everything up and replace any parts as needed. If you are lucky, the shafts and gears will be good, and all you will need to do is replace bearings. I believe all the bearings are available for that transmission. While in that far I would recommend that you take the rear housing off and replace the seal that keeps the gear grease out of the power take off clutches, unless you know that has been done of course.
bunghammer
08-04-2007 12:06:55
You might want to check the detent balls and springs for the shifting forks, thay may be stuck or the springs could be broken. This can cause the forks to move and displace the gears. You might also just have some worn out gears. Sounds like a good time to repair the tranny when you redo the rest of the tractor. Bumghammer
