How to straighten a loader?
lekander883
08-03-2007 13:57:13
When I lower my bucket my left side will hit the ground first. Leaving my right side up about two inches. In order to make them both flat I have to apply down pressure, and usually making the left side dig in to the ground. Anyway how can one go about straightening out a front end loader?Loader is a pretty heavy duty two stage, on a 1020 JD. Thanks, Troy
Tx Jim
08-04-2007 05:49:36
 Re: How to straighten a loader? in reply to TimS in Mo, 08-03-2007 13:57:13
Check and/or alter air pressure in rear tires can change bucket level on frt end loader! Tx Jim
low budget
08-04-2007 03:28:16
 Re: How to straighten a loader? in reply to lekander883, 08-03-2007 13:57:13
You could put smaller tires on the right side of the tractor. :>)
Roy Suomi
08-03-2007 21:56:45
I've cut the loader arm several inches up from the bucket pins and rewelded a well grooved "incision" for adequate weld penetration..You can also plate the repair if you feel the need..Done it many times with good luck...
LFN
08-03-2007 20:04:26
reverse hoses on one cylinder and gently nudge control until straight
G/MAN
08-03-2007 15:37:35
Find a body shop with a frame machine.
Maark
08-03-2007 14:41:33
Put a block under the low side and apply down pressure. You may have to experiment with the size of blocks and the amount of time pressure is applied.
