60 that likes hunting
HaroldIHC
08-02-2007 19:15:24
Purchased a 1954 JD 60 at an auction this spring. I was lucky it wasnt stuck. I had to install new manifolds, a new battery and some gas and she started right off. Blew out the carb before I put it back on. The tractor pulls good but wont idle. If I short # 1 plug it idles nice, iff I short # 2 plug it goes hunting and adjusting wont help. This I think tells me that some tunnel in #2 venturi is pluged. took the carb off but cant find the tunnel. Need advise or if possible a pic with directions. Thanks much. Harold
Jturbo10
08-04-2007 19:12:00
 Re: 60 that likes hunting in reply to HaroldIHC, 08-02-2007 19:15:24
For every tractor and piece of major farm equipment (combine, etc) I try to get the operators manual, parts manual, service manual, technical manual, and assembly manual...plus the I&T manual (Ebay is a very good source). I have only occassionally used the I&T manuals as they are very vague with poor technical instructional. There have been a few instances where they covered an aspect of repair or contained an illustration that was useful. Mostly they are too general and leave out important steps or considerations to be very helpful. Spend your money on JD manuals first and then supplement with I&T as needed. JMHO
bunghammer
08-04-2007 12:45:33
I agree with buickanddeere about the I&T manuals. You need an sm2024, sm2008, and a om-r2034. Also a pc244 parts book woulldn't hurt. If youv'e got them your steps ahead. They are a must when you own any tractor.
Duane Larson
08-03-2007 18:35:14
HaroldIHC,
By removing a couple of freeze plugs, the idle circuit is "broken" in two and helps sort out where the problem is. Do a search in the archives for LARSON DUPLEX CARB PLUG and you'll find directions for locating and removing the freeze plugs.
P Browning
08-03-2007 15:23:21
Harold -- I do not know if you want one bad enough or not, but SM2024 is still available from Deere Publications. This one is the "bible" for John Deere Carburetors and may be the best thing since sliced bread for you -- you decide.
At any rate, should you decide to buy this "just under $50 Manaul", you can obtain it thru your local JD Ag dealer or from Deere Pubs (800) 522-7448. If buying it from the latter, you can probably get it on CD as well as on hard copy. (PatB)
HAPPY DEERE
08-03-2007 12:49:57
get an i& t shop manual
HaroldIHC
08-03-2007 14:13:32
 Re: 60 that likes hunting in reply to HAPPY DEERE, 08-03-2007 12:49:57
I have a shop manual[I&T] for the 50 60 and 70,its a good book but it dont have much on gas carbs [DLTX81] thanks anyway. -----Harold
buickanddeere
08-04-2007 08:23:11
 Re: 60 that likes hunting in reply to HaroldIHC, 08-03-2007 14:13:32
I & T shop manuals are only good for propping doors or windows open. Or used for wrapping soft metal items before clamping them down in a vice.
