1947 JD Styled D
glieck
08-02-2007 10:50:20
When you go to ingage the clutch arm there is play from left to right in the crank and flywheel assembly. With the top engine cover off you can see that the play is on the clutch side of the crank, because of how the gear on the flywheel side lines up. It has about 3/16" of play. How do I or Do I need to make this go away
Thank You
Maark
08-02-2007 17:08:07
 Re: 1947 JD Styled D in reply to glieck, 08-02-2007 10:50:20
You need to loosen the flywheel and move it further onto the crankshaft to remove the side motion. Search the archives for the proper procedure.
