Deere 894 rake
Jeremy Conaway
08-02-2007 09:59:39
I"m in the market to get an older rake to bale some grass hay on a small scale, maybe 200-400 small square bales per year. There is a Deere 894 rake for sale and the guy"s asking $600 for it. Not having seen it yet myself, he says it"s in good condition with faded paint but not all rusty. The tires are supposedly road-worthy. Assuming his description is accurate and that it is in good working condition, what is a fair price for this model?
Thanks in advance!
James22
08-03-2007 12:38:58
 Re: Deere 894 rake in reply to Jeremy Conaway, 08-02-2007 09:59:39
Probably too late for any input, but I have a 5 bar 896A. The parts book shows that bearings were offered as an upgrade to the bushings for the rake bars. Does require changing the bar end. Not as good as the NH rakes, but my experience is that it is entirely adequate for smaller acreages. I paid $650 ten years ago, but it had pretty good paint, original tires with good tread and had been stored inside. At the time a NH model 55/56 were bringing around $800. The model 258 was closer to $1500. A good JD 640 was easily over $1200. Prices appear to be lower today. I believe the 894 was a four bar rake, and for hay I generally would want a five bar, but you can add another bar pretty easy. Perhaps for grass hay a five bar is not that necessary. A four bar 894 in good shape should be worth $400. Never had a problem with the chain flying off. Perhaps because I never believed it necessary, or prudent to rake over approximately five mph.
Jeremy Conaway
08-02-2007 19:53:39
Thanks for the good info, guys. That"s the sort of replies that are so helpful to us not-so-knowledgable"s.
55 50
08-02-2007 17:41:56
I have an 894A. Just use it for a very small amt of bales (under 100 a year) on a hobby acreage. Paid more than I should have but I couldn"t afford a NH which go for usually twice what I paid for the 894A. As I said I paid too much and am embarassed so I won"t tell you how much, but I will agree $600 is too much! Only thing is I had to replace a couple boxes of those rubber mounted teeth - they are reasonably priced though.
I wonder what the differences are between the 894 ansd 894A. From looking at the Parts Catalog it isn"t very obvious on differences.
ET
08-03-2007 12:36:07
 Re: Deere 894 rake in reply to 55 50, 08-02-2007 17:41:56
The diffrents between the 894 and the 894A is the 894A has rubber mounted teeth and the stripper houps are shaped a little diffrently to acomadate them. I think 600 is about double what the rake is worth. I had a 896A and it was a real good rake, the fellow I sold it to is still using it and likes it better than his New Holland.
Mark in No Iowa
08-28-2007 08:27:37
 Re: Deere 894 rake in reply to ET, 08-03-2007 12:36:07
I just paid $175 for a 894, but have to replace about 30 rubber mounted teeth on it.
Chris in MD
08-02-2007 12:21:18
NO NO NO NO NO WAY!!
We had one on our farm about 5 years ago. The driveshafts wobbled and the chain drive often jumped. Not to mention the fact that the angle of throw of the swath is not enough, as the hay got caught in the middle of it, and pretty much tied the hay in a knot. It would often bind up and cause the drive tires to bounce.
We eventually bought three wheeled new holland rakes. (GREAT BUY)
I FINALLY sold the hayrake for 200 bucks. 600 bucks for one is HORRIFYING. Please run far away.
Mike Aylward
08-02-2007 12:14:23
Jeremy, the 894 is a 7' unit that was last made in 1964. It, and it's larger brother 896 were designed as "economy" rakes in their day. The tooth bars on the reel only have bushings instead of bearings and as these bushings wear they let the tooth bars have a lot of slack. This can make the bars droop back and not pick up the hay well. Also, the drive axle on the 894-896 rakes is straight while the later rakes have a staggered axle allowing the right hand wheel to be closer to the rake. I am not sure of your location but for not very much more you can find a 640 rake which is a MUCH better rake. If it were me, I would pass on the 894. My humble opinion. Mike
