4020 miss in one cylinder
JD6030 puller
08-02-2007 07:59:01
Just put new rings and bearings in 4020. started up and smoked white really bad, reeved up slower than normal and had a miss at higher rpm. checked timing many times. cracked the injector lines, second cylinder from back did not change engine like others did. checked injector was good. all valve train looked good, also valves looked to be opening and closing correctly. took piston out and all the rings are good. didnt look like this was firing at all. confused!
bunghammer
08-02-2007 10:24:27
 Re: 4020 miss in one cylinder in reply to JD6030 puller, 08-02-2007 07:59:01
Did you check th valve settings? When those cams get worn it gets pretty hard to adjust the pump timing from the play in the gears.
buickanddeere
08-02-2007 09:10:44
It's either the injector, pump or as previously stated the cam. Few do more than glance at the cam & followers during a rebuild or a ring job. If you use a degree wheel and a dial indicator on a used cam. You will be ordering a new one or a re-grind when you see the numbers. You can't see the wear that will reduce power or efficiency with the human eye. Try trading the #2 & #3 injectors. You did take them all out,had them tested and had new tips installed? Did you use new cylinder head bolts, main and connecting rod bolts? Fasteners do go soft or hard with years & usage. It's not impossible the head gasket is seaping enough to lower compression?
Bob
08-02-2007 08:17:20
Have you check for valve "lift" on that cylinder? The cams DO "go flat" from time to time.
