JD 2020 Transmission won't disengage
Bill S
08-01-2007 08:25:42
Depressing the clutch will not disengage the transmission. I assume this is a clutch problem but my manual indicates this could be a failed transmission snubber brake. I have ajusted the clutch which did not fix the problem. What is the more likely cause?
Bill Sanders
08-01-2007 09:48:38
 Re: JD 2020 Transmission won't disengage in reply to Bill S, 08-01-2007 08:25:42
The tractor sat for a few weeks before this occured. The pedal pressed feels good. When I opened the inspection cover, I notice moisture and rust in the clutch housing. So the clutch is most likely rusted to the flywheel?
wilamayb
08-01-2007 09:02:05
Yes it does indeed sound like you have a clutch problem. Clutches have been known to rust themselves to the flywheel in turn the pressure plate cannot release the pressure of squeezing the floating disk between itself and the flywheel. Another possibility it that the clutch fingers have actually broken off which causes the same problem as above with the pressure plate.
A couple of questions to help the experts here. Are you feeling the normal amount of resistance when you depress the clutch? Did it happen suddenly or did it gradually become worse over time? Has this tractor been sitting for quite some time?
Bill Sanders
08-02-2007 12:15:40
 Re: JD 2020 Transmission won't disengage in reply to wilamayb, 08-01-2007 09:02:05
Cleaning the clutch with brake cleaner and holding the brake with the clutch depresed didn"t work. The inside of the clutch housing was completely covered in rust. I found the weep hole at the bottom of the housing, it was blocked. I drained about a pint of water out. I prepared to split the tractor. Assuming this is a rust problem are there any tricks to fix the problem once the tractor is split?
machinery-man
08-01-2007 09:10:34
You don"t have much too loose, but I would remove inspection plate and spray innerds with brake cleaner, get the tractor going in 4-5 gear and push in clutch and stand on both brakes, the plate may be seized and this would allow it to break free...then keep appling some cleaner...worth a shot, what ever you do don"t monkey with it off tractor while engine running just in case there is a loose lining, you may be in an accident.
Mike M
08-01-2007 10:53:17
 Re: JD 2020 Transmission won't disengage in reply to machinery-man, 08-01-2007 09:10:34
If you do both brakes it likely won't work. Just do one brake at a time and hang on ! I have had real good luck with this method after reading about it over at the 8N board.
CharlieMc
08-01-2007 14:39:27
 Re: JD 2020 Transmission won't disengage in reply to Mike M, 08-01-2007 10:53:17
That's interesting. Why would holding both brakes not help loosen the clutch plates? Why does pushing one brake at a time work better? I would think this would be more dangerous.
Always learning something new on this site.
Thanks.
Mike M
08-02-2007 05:24:48
 Re: JD 2020 Transmission won't disengage in reply to CharlieMc, 08-01-2007 14:39:27
I'm not sure,but both brakes don't seem to do it as it puts a steady loading on it where as just one brake must send a shock wave up through it.
I have tried the both brake method many times before. Even hooking to a stump on some. I was able to get in at the disk on one and with the pedal tied down and some pressure on the tranny in gear bumped the starter and took a screw driver and poped it loose.
After I read on here about getting them going fast by shifting up through the gears trucker style,let off the gas and then shift then go again,the hanging on and jambing just one brake I have had success on the few I've tried it on. Very fast and effective. Just do it in a wide open flat area. I then after it's loose put it in high gear and slip it some ,but try not to get it very hot, this seems to clean them up.
