530 gear shift
bob from missou
07-31-2007 05:57:43
i have a jd 530 that when i go to move the gear shift it feels as if it wants to pull out? is there a pin or something in there that may have broke or came out? and if so how hard to fix, do i need to take it to someone that knows what they are doing? thank you bob
Michael Sheik
07-31-2007 06:53:09
 Re: 530 gear shift in reply to bob from missouri, 07-31-2007 05:57:43
Just had the top plate off my 830 with shift levers last week. Unbolt and pull it off. It is real straight forward with that snap ring discussed above. Hope that snap ring is still on the shift lever and not down somewhere in the gears. One more thing - Check that shift lever to make sure it is straight. If it is bent, straighten it and shifting will be much easier. That was my problem! Another bit of advise. If you have to use more than two fingers to shift it into gear, my opinion is that your applying to much pressure on the lever. It does bend, believe me! The previous owner of mine did it.
Machinery-Man
07-31-2007 06:25:45
There are C type keeper rings on the shaft. The lower ring fits under the ball and the upper snaps at the shield. It appears the upper ring has moved out of the slot. What I've done in past is remove quadrant, remove the ball at top of shaft remove keeper and slid shaft out. The upper is spring loaded. Then I got new keeper, took a new file and carefully cleaned the groove, then reinstalled the keeper. You have to slide the keeper down the shaft not try to seperate to instal and they spring open and will not be secure. I may be over the top for you if you've had no experience but you should be able to locate a club/individual in your area. Good luck.
