48' A Compression test
MJF
07-30-2007 20:01:22
I have a 48' 2-shift A when I got it there was a big hole in the manifold and was ran like that it might have burnt the valves but I did compression test and the one side has 110psi and the other side has 130psi. From what I've heard 130 sounds pretty good you guys think maybe theres been a little work done to it or not? I believe in a couple weeks I'll tear it down and do a valve job and maybe throw a set of rings in it. What do ya guys think of my readings
Mike
Mike M
07-31-2007 05:06:35
 Re: 48' A Compression test in reply to MJF, 07-30-2007 20:01:22
Those readings sound good,but how fast did it build up ? Sometimes you get a piece of something under a valve and it can work out and check different later on too.
Nothing wrong with pulling it down and going over it. Most of them I've pulled apart needed some valve work anyhow. If you don't find much wrong it doesn't cost much and at least you know what you got. If you do find alot of problems then your darned glad you pulled it down.
HAPPY DEERE
07-31-2007 04:49:26
not to bad but my rule of thumb is no more then 10 difference if you want put a set of alum pistons in it
