JD 5510 Problem
mitchash
07-30-2007 12:02:28
Was brush cutting in the back field when our 5510 just quit (has 6000 hours). It turns over, has over half a tank of fuel. I checked the fuel filter and bleed the system. I checked the fuses (electronic shut off?). Any ideas? Thanks, Ash
G/MAN
07-30-2007 13:32:53
 Re: JD 5510 Problem in reply to mitchash, 07-30-2007 12:02:28
Can you hear the shutoff click when you turn the key switch on? You could have an open in the shutoff circuit between the fuse and the pump itself. You might try a jumper wire from a source of battery voltage to the shutoff terminal on the pump.
