JD 4450 or go newer?
mudraindirt45
07-29-2007 23:45:42
Hi there. I'm looking at a late model 4450 Deere with only 2300 actual hours. It is a powershift and two-wheel drive. Had new Firestone 23-degree radials put on last year and had the original tires on at the time,which I thought was pretty amazing. It was bought by an older gentleman who just used it to brush-hog and pull wagons with,it looks and runs like brand new. I realize that most tractors of this age have alot of hours by now,so this is a great find. Asking price is 35,000 firm. Now to my question...would you buy this or go to a newer model? I also looked at a 7800 with powershift,and also two-wheel drive. It has 3400 actual hours,seems to run very good also. It has 80% Michelin radials on it. Previous owner informed me that pump had been tuned to 170 horse. He is asking 43,000 for it. My budget is about 50,000 so price is not a problem on either. Any comments on what you would do,or experiences with these two tractors would be appreciated. Thanks in advance and God bless. Hank
low budget
07-31-2007 06:40:03
 Re: JD 4450 or go newer? in reply to mudraindirt45, 07-29-2007 23:45:42
My big tractors are only as new as the 20 series, so I'm not really qualified to make specific comments on either tractor. But you have a choice between a tractor thats been treated well and one thats been turned up and probably worked hard. Seems to me the older well cared for tractor would be the way to go.
Matt Weltz
07-31-2007 11:36:29
 Re: JD 4450 or go newer? in reply to low budget, 07-31-2007 06:40:03
I agree. I would go with the one that you know has had an easy life and been well-cared for. If the other one has been turned up, it means it wasn't big enough to get the job done. That means it has been worked hard, and probably has a thing or two wrong/or going wronf with it. Just my experiences though...
G/MAN
08-01-2007 07:40:53
 Re: JD 4450 or go newer? in reply to Matt Weltz, 07-31-2007 11:36:29
Not necessarily. I'm not a big fan of turning tractors up, although I do it from time to time when customers request it, but if the operator has a clue and you're not trying to double the horsepower, it can be done safely and without reducing reliability. Any heavy-duty diesel engine has a considerable "safety margin" built into it, and often times the same internal components are used in engines that can vary widely in horsepower ratings. Turning a tractor up 10-20% usually won't hurt it at all if it's in good shape to begin with. My grandpa bought a new IH 1086 in '80, and had it turned up to around 150 horsepower a year or so after he bought it. The first 5 or 6 years of its life it was the main field tractor - heavy tillage like plowing and disking, planting, cultivating, etc. In country where a 5-bottom plow would work it pretty hard in clay gumbo bottom ground. Later it moved to lighter work like haying, and ultimately ended up as a loader/grinder tractor. The original engine went 12,000+ hours without the head ever being off, thanks to proper operation and good maintenance. As for the 7800, I doubt it was turned up very much at all, since that's about a 150-hp tractor to start with, and I've seen some that would make close to 170 with the lock wire still on the pump.
.G/MAN
07-30-2007 13:46:42
Depends on what you want it to do. The 7000-series Powershift trannies don't have a sterling reputation, but it's not due to reliability or quality issues. It's usually to rough shifting complains etc., many of which are due to operator error. And even a "rough shifting" 7800 had shift every bit as well as the smoothest-shifting 50-series powershift I've ever been around - any electronically-controlled transmission is way more capable of matching shifting to varying loads and conditions than any mechanical-controlled powershift. The 7000 will also have a more comfortable cab - air-ride seat, easier to get in and out of, much quieter, nicer controls, etc; be easier to service; have a much more capable hydraulic system; 19 forward speeds compared to 15; possibly a higher transport speed; side exhaust; better lighting and the list goes on and on. The 4450 is a heck of a tractor and was probably the best built by any company in that power range and time period, but a 7800 is simply a couple generations newer, is of a completely different and then-new design, and in most areas there's really no comparison.
Tx Jim
07-30-2007 04:04:21
 Re: JD 4450 or go newer? in reply to Dave in SV, 07-29-2007 23:45:42
The powershift on 4450 is not controlled by electronics as on 7800. Had a neighbor that traded off a 7400 PS because he got tired of not being able to keep it shifting correctly. Local dealer couldn't repair it either. 4450 rides better than later models IMHO. Tx Jim
