2150 three point question
Brent McIntosh
07-29-2007 15:11:05
Hello
Should the pump run all the time on a 2150 if the three point is in the raised postion? If you idol the tractor down you can here it pull down as if the pump is running and if you let the three point down the motor sounds if the pump kicks out. thanks for the input Brent!!
Tx Jim
07-30-2007 04:22:42
 Re: 2150 three point question in reply to johns48jdb, 07-29-2007 15:11:05
Brent if main pump continues to pump oil after 3pt is raised you have a leak in rochshaft control valves or valves aren't adjusted correctly to neutralise in fully raised position. Remove hyd oil filler cap with engine running and 3pt raised,look inside filler hole for spraying oil. Tx Jim
buickanddeere
07-29-2007 22:28:08
 Re: 2150 three point question in reply to Brent McIntosh, 07-29-2007 15:11:05
Both pumps always run. The trans pump always at full flow. The front pump is variable flow. There should not be oil flow through the rockshaft circuit once the arms have been raised to the intended height.
