Help! Model D men
ted dixon
07-29-2007 05:00:12
Guys, Have a 1930 model D that I have been working on for awhile. This tractor constantly backfires and will not run smooth. It acts as though it fires two or three times in a row and then quits and then fires the same way again,(engine does stay running), also the governor is constantly opening and closing (hunting) the whole time this is going on. It has the Dltx 3 which has just been rebuilt by a pro. Also I thought it could be the mag so I replaced it with a brand new Wico XH1263, new plug wires, new plugs, has brand new fuel(drained everything to begin with),and the tractor only runs slightly better than when I bought it. I am at wits end with this one. Any and all help greatly appreciated. Thanks.
ted dixon
07-29-2007 16:01:04
 Re: Help! Model D men in reply to ted dixon, 07-29-2007 05:00:12
Guys,
Fired up the D again this afternoon. Turned load needle all the way down and tractor would run, did same thing with idle circuit and it would run. Opened up needles again and started backfiring. I walked to the other side of tractor and a "flash" caught my eye. Tractor was firing out from under intake manifold gasket. Shut it down to remove nuts from manifold but a nogo. Finally took a grinder and cut nuts off to remove. Gasket is nothing but rust and falling apart, manifold is also broke on one corner. I see that I definitely need these two items. This is where I am so far. I need a new or good used D42R manifold and also a new D306R gasket if anyone knows where some are at. Checked Deere and don't see gasket available and I'm sure manifold is out of the question.
WeirdDeere
07-29-2007 17:49:02
 Re: Help! Model D men in reply to ted dixon, 07-29-2007 16:01:04
Rosewood Machine Co has brand new manifolds.
www.rosewoodmachine.com
I'd bet they have the gaskets, or K+K tractor parts has them listed here
Good luck getting that D running the way it should!
Brandon
HAPPY DEERE
07-29-2007 15:02:45
make shure you wires made for a magneto and then try a hotter plug
bigblock
07-29-2007 08:11:31
plugs and wires should fix it.it simply is not burning the fuel until it gets in the exhaust.
Scott in WI
07-29-2007 06:46:13
Hi Ted, Not sure if this helps or not I had a 1936 B that did the same thing. Previous owner put new spark plug wires on, however they were the automotive type, not the solid core you get from John Deere. Put new wires on and solved my problem right away.
ted dixon
07-29-2007 06:40:44
Pat,
I,m sorry I should have clarified about who built the carb. Burrey Carb repair did the job and they have done several in the past for me and I have not had a problem with their stuff yet. I will try those tests and will post back with resuls. Turning the needles yesterday does make the engine sound different but not "run" different. I've looked at your site before and like the info you have. Great site!
Mike M
07-29-2007 08:17:26
 Re: Help! Model D men in reply to ted dixon, 07-29-2007 06:40:44
That carb. guy may be a pro, but his carb. still may not be right ! He did one for someone around here on a JD H and this tractor gave them FITS !! They brought the tractor to me and the main problem was he doesn't put sealer on the little brass plugs in the carb. body and they suck air. So reseal those plugs then report back.
P Browning
07-29-2007 05:08:07
Ted -- I hate to say this, but whenever someone says a "pro" just rebuilt the carburetor, I get an uneasy feeling. While I am not a "D-Man", I can point you to a test or two to run on the carb, both are "no-wrench" so you haven't much to lose.
A real quickie test is to apply partial choke to see if she settles out. And if "yes", the IDLE path isn't fully open.
But a more comprehensive test is found at the JD-H Restoration Site (below). Open the site, and once there, look left, scroll down to CARBURETORS. One click on the item, then go to its page 9 for a test for IDLE & LOAD passageways. (PatB)
