2 PTO shafts.
Bill Brox
07-29-2007 03:45:25
Hello,
I have a question.
Does anyone know if someone has made a tractor with 2 PTO shafts in the rear end of a tractor ?
I have heard about several tractors with 1 in the rear, and 1 in the side, but how about 2 in the rear ?
Bill
buickanddeere
07-29-2007 22:34:24
 Re: 2 PTO shafts. in reply to Bill Brox, 07-29-2007 03:45:25
1010 could be ordered with two shafts, one 540 & the other 1000rpm. The post 125,001 420,430,435 & 440 could be had with either a 540 or 1000 rpm lower shaft. An upper shaft running at engine rpm at the same time was possible if equipped for a trencher attachment.
Waterloo
07-29-2007 11:48:29
Bill,There were a few (very few) DI John Deeres built with two PTO shafts. If you will give me your E-Mail address I can send a couple of photos of these tractors.
WeirdDeere
07-29-2007 14:14:18
 Re: 2 PTO shafts. in reply to Waterloo, 07-29-2007 11:48:29
I would like to see these pictures too. Are they original B+W pictures, or a restored example? I've yet to see one that still exists today!
Brandon
[email protected]
Bill Brox
07-29-2007 12:46:58
Thanks, :-)
[email protected]
Bill
WeirdDeere
07-29-2007 14:22:24
 Re: 2 PTO shafts. in reply to Bill Brox, 07-29-2007 12:46:58
For your info, about the dual PTO on a model D industrial "DI"...I can only look at the original illustrations and pics, but I don't think these shafts had the normal spline pattern seen on a modern 540RPM PTO. I doubt they even rotated at 540RPM, probably a bit slower. I'm pretty sure they could be reversed too. They were used to control the blade angle, etc on a trailing scraper (replacing the hand control wheels seen on most scrapers of the day). It made road scraping a one man operation.
Brandon
ram ranch
07-29-2007 04:30:25
International and the industral John Deeres ptos were top and bottom. Really thats the only way they could be for turning reason.
ram ranch
07-29-2007 04:07:10
are you looking for 2 ptos or two speed ptos? Internatioal has two ptos and they run 2 different speeds 540/1000 some industral John Deeres have two ptos on them for running scrapers. There were some John Deere model Ds that had two ptos but I really don't know the speed. I would think they were 540, they where industrals also. Just what are you looking for/to do?
Bill Brox
07-29-2007 04:11:43
 2 PTO shafts. in reply to ram ranch, 07-29-2007 04:07:10
Thanks, :-)
I mean 2 separate shafts, one on the bottom and one above, in the rear end.
Bill
