Anyone redo one this bad II
Farmall MD
07-28-2007 14:00:24
third party image
Thanks for all of your responses to my first post. I was at my pop's today and looked at it a little more today. It is a '36 SN# 434420.
I remember when my dad moved this about 25 years ago to where it is now. He had to pull the brake housing on the left side cause it was rusted fast. When he put it back in, it was just loose. I pulled it out with ease, and looked inside. NOT A SPEC OF RUST was visible. So this might not be as bad as I thought.
It was bought in '49 and used on the farm 'till about 58, when it was parked. It had a new JD block in it when it was parked, maybe salvagable by boring out? Also has the original spoked wheels in the front. They were never cut for bolt patern hubs. Front rims are good, but needs back. The backs were filled with calcium. All the spokes are good, so all I'd need to do is weld on other rims to the spokes.
I'm real anxious to get started on this thing now. Doug N
Ken L.
07-29-2007 06:39:20
 Re: Anyone redo one this bad II in reply to Farmall MD, 07-28-2007 14:00:24
Detwiler in Spencer Wi. does rim replacement.
FarmallMD
07-29-2007 10:34:45
 Re: Anyone redo one this bad II in reply to Ken L., 07-29-2007 06:39:20
Thanks Ken, I'll look into it. Might be expensive to ship to Wisconsin from PA, but these rims are rare and worth it. Doug N
Mike M
07-29-2007 15:34:00
 Re: Anyone redo one this bad II in reply to FarmallMD, 07-29-2007 10:34:45
I have always done the heart of the tractor first and left stuff like sheetmetal and rims and tires for the end.
I have seen and even bought some where people were to concerned about the tires they fixed that but the rest of the tractor wasn't worth fixing. Just driving around for a test drive or to load on a trailer you can run on the rims and it won't really hurt them.
Ken L.
07-29-2007 14:02:33
Might be on the expensive side but, they do good work.
Hoss in Maine
07-28-2007 17:19:43
I did a 1928 gp that sat for bout 30 yrs.Youd be surprised,crankcase was good even bearings but was stuck.One cylinder was half full of sand other was not stuck as valves were closed. Freed up easily.I did a quick valve job,cleaned carb and points.I did belt up a 3hp fairbanks morse eng to it to start it though. later Hoss PS go for it
Mike M
07-28-2007 16:16:53
If it has original round spoke rubber rims and it appears it might then you may be well advised to spend some money on them and have someone who specializes in restoring those wheels fix them. I think they advertise in Green Magazine and Two Cylinder. Those rims are potentally worth more than the rest of the tractor !!!!
Ry
07-28-2007 14:19:06
I would say it could be done. I have done ones that looked much worse. What the heck - it was in your family. Might be nice to do something with it.
