4300 down on power?
mike wahl
07-28-2007 11:58:05
when i mow {w 72 belly unit} i try to keep the "540" rpm on the tach but tractor seems to slow down ?no matter what hydrostat range i am in? even sometimes on flat ground ? i just bought it and have changed fuel filter {was hard to blow thru/? the loader is still attached ?would that draw some power down? or maybe there is a bad collapsed fuel line ? or is this a problem w/ a 72 " {too big ?} deck ? tractor has 1600 hrs thanks for any ideas you might have !
mike wahl
08-29-2007 20:49:38
 Re: 4300 down on power? in reply to mike wahl, 07-28-2007 11:58:05
i have not had much time to work on the 4300 ,but was wondering if the fuel pumps on these models give owners much trouble ? i did notice that if you raised the power up& down on the deck and the lever sticks a little the tractor seems to be down a little on power ? also my blades are dull,i think i will sharpen and mow more thie w/end thanks guys
mike wahl
07-28-2007 18:15:34
thanks for some ideas ! the fuel shut-off was kind-of hard to get turned off and on? it seemed like it had slop in it ?or should i say felt loose ? in the on position? yes i believe the filters are ok BUT will double check! where i bought it the fuel line had a leak ?i believed they cut it off and shortned it ? thought maybe hose had a bad or soft spot / collapsing? anyway i might ck into the valve adjustment?is it a fairly easy job for a gasoline machanic ?if anybody else has any ideas feel free to tell me !
Jm Fisher
07-28-2007 12:54:43
I've got a 4300 hydro with the 72" mower. Mine will hold 540 rpm in B range in just about all conditions. I have a lot of hills and have to let up on the hydro pedal when going up hill but I can mow down hill or on flat ground with the pedal close to full down.
Check to make sure that the fuel shutoff valve that you closed to change the fuel filter is open all the way. The last time I changed a filter (1500 hour service), I had to take the valve apart to get it open.
Also check to make sure that both air filters are good (there is a filter minder under the hood) and that the hydro fluid is up to the proper level (sight glass on the rear of the machine).
Do you know the service history of the machine? Deere recommends a valve adjustment every 500 hours. I haven't noticed a big improvement in power after adjusting the valves, but it does seem to run a bit smoother.
If you have the quick-tach Deere loader (420 or 430), you'll probably want to take it off to mow, particularly if you have a lot of obstacles to mow around.
mike wahl
07-28-2007 18:19:49
 Re: 4300 down on power?cruise control ? in reply to Jm Fisher, 07-28-2007 12:54:43
i forgot to mention in my "loss of power " issue that my tractor is equipped w/ cruise !i think and it dont work i dont have a schmatic or book ,anybody have any ideas where power is found or how it works ?
Jim Fisher
07-28-2007 21:21:16
 Re: 4300 down on power?cruise control ? in reply to mike wahl, 07-28-2007 18:19:49
The cruise control uses an electromagnet to hold the hydro pedal in one spot. There is an interlock with the master brake pedal (the one on the right) that releases the cruise when the pedal is depressed. Assuming a 2000 or newer tractor, if the brake lock linkage doesn't go all the way back to the rest position, the brake pedal switch will prevent the cruise from engaging. Press the cruise button and watch the indicator light. If it blinks but goes out right away, you need to look at the parking brake linkage. Otherwise, check the fuses in the panel below the steering wheel.
