40T wiring etc
Pete in New Yor
07-28-2007 05:31:42
Hi: I have a 1953 40T that was converted to 12V. The wiring diagram shows a wire going from the hour meter pickup on the engine to the coil. This wire has been cut. Can I run a wire to the coil, or do I need some kind of resistor since the tractor used to be 6V? If it needs a resistor, where would I find one?
Also the dash is currently green, should it be black? And what color black?
thanks for any help.
John T
07-28-2007 06:53:08
 Re: 40T wiring etc in reply to Pete in New York, 07-28-2007 05:31:42
Whether or not you need an external ballast resistor depends on if the coil is a 6 volt (ballast required) or a 12 volt (no ballast required). The primary resistance of a coil (between lil + and - terminals) will be around 1.5 to 2 ohms if its a 6 volt but more like 3 ohms or more if its a 12 volt. Ballast resistors are around 1.5 to 1.85 ohms and are readily available at Tractor Supply or Rural King or Central Tractor or NAPA (part # ECHICR13) etc.
If you use 12 volts on a 6 volt coil it will run too hot and the points will burn up prematurely,
John T
