4020 oil idiot light
Nylon
07-28-2007 00:44:58
Anyone have a pic of which hole the idiot light oil sensor goes to in the oil gallery? Also anyone know where I can find an oil sensor? I have a good working oil indicator lamp in the dash with plugs but that is it...missing everything after that. Also looking for a cigarette lighter. Any old car cig lighter from a junkyard work? Don't smoke...just want to put one in there.
Thanks,
John
Bob
07-28-2007 09:01:13
 Re: 4020 oil idiot light in reply to Nylon, 07-28-2007 00:44:58
The oil sender goes in the oil gallery hole sort of hidden 'cause it's on the backside of the engine ventilator tube dropping down from the valvecover.
The sender is # AT85174, a little less than $20.00 at your Deere dealer.
Tx Jim
07-28-2007 03:42:38
 Re: 4020 oil idiot light in reply to David from Kansas, 07-28-2007 00:44:58
The engine oil sender screws in a hole behind speed/hour meter drive cable. An automobile cigar ligther element should work if it's not a metric one. Tx Jim
Nylon
07-28-2007 20:31:22
 Re: 4020 oil idiot light in reply to Tx Jim, 07-28-2007 03:42:38
Either of you guys sell jd parts? I would like to buy a sender and have it shipped. Also, I see two possible spots to put oil pressure taps. There is one verticle threaded hole to the left of the injector pump. Behind the valve cover breather tube. This one has a brass threaded plug in it that isn't factory and am guessing that this is where the original oil light sender went to. There is also another hole with factory plug below that one. It appears to be the same as what I am pluged into with my oil pressure gauge line. The current line in is in a hole below the fuel filters low on block just above frame rail but above where the block flairs out to rail. I pluged back into the same hole that my plastic line was plumbed into. I switched to copper but want to get that side of the engine tidy. As there are hoses and lines everywhere. Cab heat lines x2, oil pressure and engine coolant heater x2. Want to move my copper line to back of block so it is behind that rear side panel. The verticle hole is a bit higher on the block. Is this low enough to plumb into for oil pressure?
Thanks,
John
