John Deere 1530 oil leak
backwoodsfarm
07-27-2007 18:59:59
I have a 1530 that is leaking hydraulic oil around the PTO shaft. As long as I park it facing downhill it's not bad. I removed the housing and shaft, installed a new oil seal and put it back together. Darn thing still leaks, maybe even worse than before!! Am I right to assume that something is worn in there? Would a speedy sleeve work and if so, how do you install one? Any input would be greatly appreciated. Thanks.
