Hood bolts, bushings, spacers,etc.for 630
EHinSC
07-27-2007 11:57:47
JD Parts lists several items as "invalid part number". Specifically:
AR20946R,R20817R,R20818R,AR20945R,AR20946R,R20912R
Anyone know where to source these? Thanks for the help!
CLW
07-27-2007 13:53:13
 Re: Hood bolts, bushings, spacers,etc.for 630 in reply to EHinSC, 07-27-2007 11:57:47
If you can't find what you need contact "Correct Connection" 1-814-926-2777 or email: [email protected]. I got the complete set for my 630 from them (hood, grill and dash) a few years ago and was very happy with them. Don't recall the price but it was fair, otherwise I would recall it. third party image
P Browning
07-27-2007 12:23:01
EHinSC -- JD Parts will list these parts if you drop the "R" suffix. All are current, two bolts, two spacers and one a plastic washer.
You will learn that AR20945 is replaced by 19H1905, and AR20946 is replaced by 19H1900. The part description comes up so that you can verify the replacement is for you. (PatB)
EHinSC
07-28-2007 09:57:25
 Re: Hood bolts, bushings, spacers,etc.for 630 in reply to P Browning, 07-27-2007 12:23:01
Thanks, Pat and CLW! I did not know the trick about dropping the suffix, is that true of most parts that come up as "invalid"? Again, appreciate all of the guidance!
P Browning
07-28-2007 11:30:26
 Re: Hood bolts, bushings, spacers,etc.for 630 in reply to EHinSC, 07-28-2007 09:57:25
Dropping the R suffix is becoming more the rule as each day passes. It seems to do the trick for all parts where Deere has assigned an R prefix, and has long been true for bearings.
If there is any rule of thumb at all these days, It is this: Look up the part number as you have it in your parts catalog. (1) If it comes up valid, then you are home and the screen that comes up will tell you if a substitute number is assigned, and you will also have a description whereby you can tell you have the right data. (2) If it comes up invalid, drop the suffix and try again. And if it comes up valid, See (1) above.
You are surely welcome to the help -- 'pleased to be of service. (PatB)
