'75 830 tachometer
Michael Sheik
07-26-2007 17:58:57
I knew something was wrong with the tach before I bought it. Took the old cable housing off and there was no cable inside so I went to JD and bought new cable/housing. I also noted with the cable off the tach and trying to turn the tach with my fingers that it seemed direct drive to the needle and the needle does go thru its motion. I do not think this is right because when the cable is hooked up it would just spin the needle non-stop. I thought there was some sort of a friction drive in there that would allow you to spin the cable entry end of tach and needle would move based on speed turned. Guessing its gummed up inside or screwed up. Can I squirt something up the cable end of tach to free up gum or does it have to come apart which I doubt is possible. If I can't get tach working, where is a good place to look for a used working one. JD wants a bunch for new.
Jeff in TX
07-28-2007 10:31:10
 Re: '75 830 tachometer in reply to Michael Sheik, 07-26-2007 17:58:57
Worthington tractor has a couple of good used tachs and 1 new one. E-bay has a couple of new ones for around $155. I know what your saying about a new tach from deere. Havent decided which way I am going to go myself. Jeff
Mike M
07-27-2007 04:58:13
I can't seem to follow what you are asking. Might be too early in the morning ? LOL
I test tachs with a variable speed drill. Hook it into the tach and run it and see how it goes. The needle will move all the time it is running , but the faster you go the higher it should go.My drill has the rated speed posted on the tag and with it maxed out the tachs read the same RPM.
Michael Sheik
07-27-2007 09:58:32
 Re: '75 830 tachometer in reply to Mike M, 07-27-2007 04:58:13
The problem is most likely my wording. Not for sure but I think the tach may be binding up inside. On the end that cable screws on, if you turn that with your fingers, the needle turns the same amount as you turn that end. i.e.-the needle turns 180 degrees when you rotate that end 180 degrees.
