430 and brush hog
Smokin
07-26-2007 15:53:28
What size brush (bush) hog is a 430 capable of operating?
machinery-man
07-27-2007 09:05:17
 Re: 430 and brush hog in reply to Smokin, 07-26-2007 15:53:28
Wouldn"t matter if you have live pto or not as to the value of the overide clutch and slip clutch on the mower. The over ride keeps the back lash from the power to push the tractor and the slip clutch makes the impact of the blades stay at the mower without telescoping back throught the PTO shaft. or one other is do none of the above and hope for the best.
Dave H
07-27-2007 11:51:37
 I don't understand in reply to machinery-man, 07-27-2007 09:05:17
If you have a live pto and push the clutch half way down the stage of the clutch that drives/moves the tractor will quit driving the tractor forward just like a conventional clutch. So you will be sitting there with the drive clutch in and the tractor not moving and the pto still runing. When you push the clutch the last half down it disengages the pto drive. Things go the reverse as you start up.
an overunning sprgue will nt hurt anything, but I just don't see how it would be a necessity with live pto. Was it not the purpose of paying for live pto that you culd push the clutch in and the tractor would stop and not be driven forward by the implement?
machinery-man
07-27-2007 15:02:04
 Re: I don't understand in reply to Dave H, 07-27-2007 11:51:37
Suppose the question directed to my post. I understand that with live PTO the mower will operate independently to the drive train, however "before" you get a chance to push the clutch in like going down a hill or throttling down the rotation of the mower similar to a large flywheel is pushing torque in reverse through you drive train add strain.
Vermont John
07-27-2007 08:44:05
I run a JD LX-5 on my M. It does just fine and is light enough for the M to pick up nicely. The M does get a bit light in the front end. I do not know if the 430 is heavier in front than an M. I"m getting some weights. I bought the LX-5 new in May. It is more expensive than some, but comes with a slip clutch and other features that make it worth it. My dealer recommended the 5" and let me take it home to test before I decided. I am glad I did not go for a 4" because it would be too narrow for my needs. I am also glad I did not buy one from Tractor Supply. That is a good store, but their cutters do not have the features of the Deere. Don"t look so nice on back, either ;)
Dave H
07-27-2007 05:39:39
You got a lot of advise about the overunning clutch but it was not addressed whether or not you have live pto. That showed up in the late 420'S. Nice plus you got 5 speeds.
Urban rumor has it that the (i think it was called cluster) gear in the trans was prone to explode when being abused. Who knows but my 420 had one crack the case when it went atomic.
You should be able to work with that if you don't get ideas of haveing the biggest and meanest tractor on the block.
James22
07-26-2007 20:51:18
I run a five ft behind my 430W and for general cutting it is all she wants. For really heavy cutting it is too much. Finish mowing you could go to a six ft. A four foot mower wouldn't cover the wheel tracks, so if the going gets a little tough with the five footer, I just use a lower gear. For the really heavy cuttting I get the JD 707 mower and the JD 730 or the MF 285.
Hayfarmer
07-26-2007 19:10:47
I use a 5 foot rotary on my 430, it is a Kin Cutter brand and not real heavy duty but works ok. Mostly cust shourter grass up to 2 feet. I use an over running clutch and highly recommend it,. Otherwise you will not be able to shift gears and may get pushed through a fence or the like. I run mostly in 1st gear except in shorter lighter stuff. I wouldn't go any bigger than the 5 foot.
machinery-man
07-26-2007 18:51:08
A 430 has a light transmission so I would recommend a 5' rotary mower and stay away from bushes. Also use an over riding clutch on the tractor and a slip clutch on the mower. Many of those little transmissions have been trashed out with too heavy use.
Al Epp
07-26-2007 18:19:20
I have a 51 MT and a 57 Gyramor that belonged to my grandfather. He bought both of them new. That pair has cut many hundreds of acres through the years. A tough tractor and a tough bushhog. I run in 2nd gear most of the time, but in really thick 3ft tall grass sometimes have to go to 1st. Your 430 has several more horses than an MT so I'm sure you wouldn't have a problem with a 5 ft.
Smokin
07-26-2007 17:23:42
On??
Lee B
07-26-2007 18:22:51
 Re: 430 and brush hog in reply to Smokin, 07-26-2007 17:23:42
The Bush.
Even though Brush makes marginally more sense, it IS Bush.
How fast you want to go thru the bush also makes a big difference, you might not be so happy stuck in first gear with a too big bush hog all the time. That problem also leads to riding the clutch troubles when the weeds get way on up there and/or real thick.
I can't say either way as I've never seen a 430 that I can remember, but I do pull a 20 foot bush hog with a 110 hp New Holland and it's working the heck out of the tractor but doing a fairly fast job on green CRP weeds up to 2 foot high. In higher weeds I have to slow down from 5 MPH or there abouts. I believe bush hog rates that mower for a 120 hp minimum - 200 hp maximum tractor so their recommendation is right on if you ask me.
buickanddeere
07-26-2007 16:45:53
Depends.
