4850 mfwd
JD Farmer
07-26-2007 13:13:30
Hey, GMan or anyone else, we are looking at a 4850 MFWD and asking if you can give us any advice what to look for. The tractor has 5000 hrs. with good care
G/MAN
07-26-2007 13:33:45
 Re: 4850 mfwd in reply to JD Farmer, 07-26-2007 13:13:30
That's not a lot of hours for that old of a tractor, particularly if it has been maintained well and taken care of. Give the front axle a good look - look for leaks in the knuckle u-joint area, maybe jack it up to check for excessive wear at the front axle pivot pins and bushings, look for leakage at the steering motor arm, etc. If it has a front driveshaft shield, slide it back and take a look at the u-joints and check for excessive play at the front differential input shaft and at the yoke at the rear of the shaft where it's splined to the MFWD clutch output shaft. Apart from those things specific to MFWD, look it over like you would a 2wd tractor - condition and level of fluids, belts and hoses, the hydraulic pump coupler, leaks, etc.
