JD 2020 Hydra Fluid in crankcase
Bill Sanders
07-26-2007 12:14:14
My John Deere 2020 has hydra fluid in the engine crankcase. What is the possible cause? This model has the seperate power steering pump which is powered by the engine, could this be the source?
PreciseFarms
07-26-2007 15:06:58
 Re: JD 2020 Hydra Fluid in crankcase in reply to Bill Sanders, 07-26-2007 12:14:14
We had to put a power steering pump on ours about 12 years ago to remedy the same problem. At that time it was $800 from deere. It was a pretty difficult job as I remember, but not too bad. But I was only 12 or 13 at the time. Within a year or two after our model, they started running the steering off the hydraulic pump. BTW ours still runs very smooth and has plenty of power, though it is mostly used for stationary PTO work. It will always be a favorite of mine.
Mike M
07-26-2007 12:41:21
About the only one I can think of ? I worked on one of those for a model 400 ind. shaft was worn where seal rides. I think a speedi sleeved saved the day as parts were NLA from Deere. Could of been a bushing in there we had to make too ? It's been awhile ( crs )
