620 ignition switch and coil
CJ 1207
07-26-2007 10:28:30
Ordered a new ignition switch for my 620 and what I received does not have a terminal to hook up the wire that runs from distributor side of coil to the new switch as it was on the old switch. I have called the vendor and have been told that it defenitely is the correct switch for the tractor. Have managed to get all lights to function as should be, and get power at the coil. The old switch looks as if it were off of a 50/ 60/ 70 as it has the voltage reducing coiled wire inside a ceramic tube that I assume dimmed the headlights when switch was in corresponding position. I understand from reading an older posting here, that the wire that runs from pole on switch (which is unlabeled on the old switch) is used to ground out the system while the ignition is in off position to prevent accidental spark if starter is engaged. I want to be able to hook this up for safety reasons. Does anyone know if there is a different replacement switch out there that has my "mystery" pole to do just that, or if there is a way to circumvent that wire?
John T
07-26-2007 10:59:20
 Re: 620 ignition switch and coil in reply to CJ 1207, 07-26-2007 10:28:30
CJ, I take it your switch DOES NOT HAVE any GND or MAG labeled terminal correct??? While many very similar switches have all the other functions that MAG or GND was indeed as you claimed to short out the coils low (to distributor) terminal when the switch was OFF cuz otherwise cranking the engine could still make em fire otherwise.
The last one I bought from an after market vendor (NOT Mother Deere but I forget who) had that terminal. Id give vendors like K & K or maybe Jim at Agri Services a call for the correct switch. I think you have the "correct switch" for maybe a 60 or 70 etc and is generic enough to be thought as "correct" by vendors who arent aware of that subtle difference.
I guess one could rig up a NC relay or switch to short the coils output unless the regular switch was on but thats a jury rig I wouldnt be too proud of lol
Let us know where you find one
John T
Mike M
07-26-2007 10:47:24
Well don't throw out your old one. I have been able to fix most of them by taking off the back and just cleaning them up. You can restake loose posts and even make new ones from copper dog tag rivets.
