JD 2020 Oil Pressure
Neil T
07-25-2007 09:34:01
Got a new to me 2020 gas. Never noticed during any test driving, but when the coolant gets up to temperature, the oil light would flicker below 1000 rpm.
As a first step, I added an automotive type oil pressure gauge, just to check the actual pressure. Per the service manual, oil pressure should be 46-65 psi at 2500 rpm. It was a low, so I added shims (per the service manual) to the relief spring. Oil pressure is still a little low, probably 35-40 psi at 2500 rpm when the coolant is normal (hot) temperature. Not way low, but a little short of the spec.
What concerns me is when operating the tractor around 1200 rpm, the pressure is barely over 20 psi.
Is it time for a new oil pump? Anyone have a gauge on a similar tractor to know what pressure the run at lower engine speeds? Anything else I should check or be aware of?
buickanddeere
07-26-2007 07:34:32
 Re: JD 2020 Oil Pressure in reply to Neil T, 07-25-2007 09:34:01
New pressure switch. The low pressure light on my 1640 trips at 10psi.
machinery-man
07-25-2007 14:54:07
I've heard that engines can also loose pressure at the cam bearings...but like Mike M. says you could roll the mains...you might just want to check and replace if necessary....
machinery-man
07-25-2007 11:49:59
From your post sounds like you purchased the sellers problem and now have the same dilema. I supposed you could spend money now and eliminate a possible breakdown which will be a lot more money. You could try to beef up oil and run as is and hope for the best. I would say 20-25 lbs at idle is not a bad pressure. You might try even another light. I would want to know the minimum pressure allowable. I know for a fact with many tractors that oil lights shouldn"t be on with any type oil when an engine is idling. If I were you I might inquire to the seller as to his representation on the sale as it sounds like a mispresentation might have taken place. You might get your money back or a portion if you paid for a fully sound operable tractor. Personally if I had asked about these things and found out later that the oil pressure was unsatisfactory I would be discussing unless you agreed to an as is sale. Of course one should check this out at time of sale. If I liked the tractor I"d probably go into the engine.
Neil T
07-25-2007 14:02:33
 Re: JD 2020 Oil Pressure in reply to machinery-man, 07-25-2007 11:49:59
At idle it is probably closer to 10-15 than 20-25.
Seems low to me, but maybe more reasonable on older gas engines? I'm not running high load, just light loader work and driving around the yard.
Mike M
07-25-2007 10:02:02
Try some thicker oil. After that then it's time to check the bearings.
Neil T
07-25-2007 10:16:28
 Re: JD 2020 Oil Pressure in reply to Mike M, 07-25-2007 10:02:02
No chance it just the pump?
I guess I'll go get some 15W-40 for now.
Mike M
07-25-2007 10:51:09
 Re: JD 2020 Oil Pressure in reply to Neil T, 07-25-2007 10:16:28
I'd go with 30W It could be the pump ? not sure what kinda setup that uses. You still got to pull the pan to get to the pump most likely so I'd check the bearings too. I have had IH pumps blow the cover gasket leaking off oil pressure before.
I'd pull the pan and look around.
Neil T
07-25-2007 12:20:31
 Re: JD 2020 Oil Pressure in reply to Mike M, 07-25-2007 10:51:09
First thing I did was change the oil and filter. JD Torque-gard 30wt.
I didn't know it was a problem, I guess when I drove the tractor around I never got the coolant quite hot enough to flicker the light. Obviously I'm not thrilled to find that the oil pressure is low. I bought the tractor from a dealer, they probably had the same issue. Never operated the tractor enough to get to the problem. Oil pressure comes up good when the oil is cold.
Since the tractor is in good shape, I'd rather opt to be on the safe side. I'll drop the pan and see what I find.
As far as checking bearings, would you just pull a main cap and inspect? I've worked on small engines quite a lot but never anything larger.
Mike M
07-25-2007 12:46:42
 Re: JD 2020 Oil Pressure in reply to Neil T, 07-25-2007 12:20:31
I think I'd pull a main cap off. I'd also get some plastic gage and try to check the clearance if they don't look chewed up ? If they look "funny" you should be able to roll in new bearings from below. I'd pull the oil pump off and look it over too. I'm going to go over to JDparts.com and see what that pump is built like. And at the very least pick up a copy of an I&T service manual to help guide you.
Neil T
07-25-2007 13:39:45
 Re: JD 2020 Oil Pressure in reply to Mike M, 07-25-2007 12:46:42
Thanks for the input Mike M. I have a JD manual, that lays the procedure out pretty clear on the pump. The only issue I see is locking the engine into TDC. It doesn't seem like there's a easy way to bar the engine over by hand without removing some of the accessories.
Since I like the tractor, I'll drop the pan and start looking around.
Mike M
07-26-2007 05:36:07
 Re: JD 2020 Oil Pressure in reply to Neil T, 07-25-2007 13:39:45
Your all set with that JD manual as there are none better.
The parts breakdown does show some changes at the oil pump by serial number. There are some o-rings on the pickup and what looks like an outlet tubes. We can only hope it is something so simple ?
