2640 charging
460 albert
07-24-2007 16:52:28
Got a 2640, early model. Batteries went dead suddenly. I put in new batteries, checked voltage at alternator output terminal, 12.6 with engine running wide open, idiot light not lit. Made the long drive to the dealer, only had the alternator along as I was not aware that these have a regulator under the dash. Alternator put out 14 volts on test stand, 0 amps, suddenly amp guage kicked in and it showed 40 amps. Dealer wasn't sure if it was a problem with the amp guage on there stand. Bought a rebuilt alternator anyway, and a new regulator. Installed on tractor, now have 13.1 volts running wide open. Is this normal? I was expecting 14.5 volts.
buickanddeere
07-25-2007 19:20:10
 Re: 2640 charging in reply to 460 albert, 07-24-2007 16:52:28
Output voltage often varies with air temperature. During winter batteries need a high voltage to charge that would boil over the same battery in summer. As previously stated. Take the system voltage reading with the batteries 100% charged.
teddy52food
07-24-2007 20:30:26
How long did you let it run? If the batteries are very low it may take a little while to get the voltage up.
Duane(Pa)
07-24-2007 18:52:47
I think 14.2~14.5 would be more like it? 13.1 sounds too low to me.
