I have at one point been considering drilling a hole through the hole unit as one and then putting a bolt in it.... but then, there would be no way to get the bolt in once you get the assembly in the clutch housing!! It sucks, it really does, to put them back together floppy like that. Even though i have machined the pulley brake and the splined shaft to fit the shaft bearing nice and tight, I despise floppy splines on the fork. I assume the only realistic way to get something to work is to go shopping through parts tractors and mate up a fork and a shaft which has the least amount of wear. This takes a while, but with my incredible luck, i found a whole unit off of a tractor that had nice splines and a tighter fork. If I were super-duper perfect, i would machine the splines back up... BUT... there's really nothing you can do for the wear in the fork itself... Some things are just not gonna happen.
