70 LP BATTERY SET UP
Texasj
07-24-2007 13:33:12
Just curious what everyone in running? 2?1? was told i need at least a 1000cca battery fo the 70.
Pitalplace
07-25-2007 13:08:14
 Re: 70 LP BATTERY SET UP in reply to Texasj, 07-24-2007 13:33:12
I have used one 12 in my 70 for the last 7 years with no problems. I also use a plastic marine type box to set the battery in help save the metal battery/seat box. You can buy the plastic boxes at Walmart.
CLW
07-24-2007 19:56:34
I ran the factory set up of two on my 630 until last summer. After having to buy two at a time at almost twice what one 12V cost a little light came on. The single 12V works just as well as the two 6V did and I have been told it will last longer. Time will tell.
55 50
07-24-2007 14:48:20
I run two 6 volts in series on my 50 just as they came from the factory because I like to keep it that way. BUT a single 12 volt is just as good, maybe even better if you"re not into originality. 1000cca is an overkill!!
buickanddeere
07-24-2007 18:18:38
 Re: 70 LP BATTERY SET UP in reply to 55 50, 07-24-2007 14:48:20
No such thing as too many CCA.
