74-830 tractor Hyd. Question
Michael Sheik
07-24-2007 07:31:47
It happened twice last night. Once when I started it up cold and once about two hours later when running and hot. What it is is that the hyd. start making a whineing sound kind of like there is air in the system. It lasts only 3 or 4 seconds and quits and the 2 point arms kind of jump/jitter a little. I am thinking it is the filter screen maybe partially plugged but can't imagine this as hyd. oil and filter changed less than a year ago but don't know if JD shop pulled and cleaned the screen at that time. Any thoughts on this? I am going to try the oil and screen thing in a day or two if that is what you all think. I would like to save the oil and reuse. Good Idea/ Bad Idea if it looks good?
buickanddeere
07-24-2007 12:36:29
 Re: 74-830 tractor Hyd. Question in reply to Michael Sheik, 07-24-2007 07:31:47
My 1640's hydraulics were noisy and jerky at times. I figured that sometime in the past 26 years either my Uncle or the JD Dealership that installed the new clutch a few years ago. They would have changed the trans filter. Pretty certain that the old black filter and the dry/brittle oil gasket were original. Hydraulics work faster & quieter now. There is a flow control valve in the trans hydraulic pump circuit that limits max pressure. And diverts oil to priorities should the filter plug or the oil level be too low. Can't hurt to monitor the trans hydraulic pressure.
Mike M
07-24-2007 07:43:46
I'd for sure take a look at that screen. I have no problem reusing the oil except you really don't know what was used ? it could be the wrong type ? or viscosity ?
Michael Sheik
07-24-2007 07:51:40
 Re: 74-830 tractor Hyd. Question in reply to Mike M, 07-24-2007 07:43:46
You would have thought that the John Deere dealership would have put the correct oil in there as they did the work on it. I have copies of the service history from the dealership on this tractor. I will look at them and see if it stated the oil info.
What if the screen is clean?
