John Deere Model A Timing
Gino
01-18-2000 18:55:19
I need to reinstall the magneto my 1935 JD A. The manual says to put a short wire in the lower terminal bend it back toward the metal case, and then turn the impulse coupler until I get a spark, and then immediately stop. Then simply replace the magneto. I believe left hand spark plug wire goes in the upper magneto terminal. Is this all I need to do to insure proper timing. Thanks to all.
zane
01-19-2000 18:28:02
 Re: John Deere Model A Timing in reply to Gino, 01-18-2000 18:55:19
That's all there is to it IF: You've positioned the engine flywheel with the timing (impulse) mark on the corresponding mark on the tranny case (which is the turn-out on the top flange of the sheet metal bearing cover bolted to the side of the tranny). The drive dogs (projections) for the mag, on the end of the governor shaft, should be near horizontal. If the engine doesn't fire, reverse the plug wires at the mag. You may have to "fine tune" it a little with the engine running. Loosen the mag mounting screws and rotate the mag forward or back to do that.
John T
01-19-2000 17:33:43
Gino, The mag can only go in right or 180 out, and it will still work 180 out if u reverse top and bottom plug wires, but many claim (althoug I find no engineering reason why) it doesnt run as well. Anyway, with top wire out mag for left flywheel side cylinder, when its at TDC on compression stroke and the LH Impulse mark on flywheel lines up with hotizonatl mark at 3:00 O Clock on side of tractor, the mag drive cog in governor housing should be horizontal. Then install mag CW as possible so its ready to trip over where the leading first rotor brush passes the top cylinder terminal in mag cap, and turn it CCW just until it trips over and that timing is close so you can fine tune it later. If thats too complicated to follow, just stick it in and if it backfires terrible reverse the two plug wires then you can reverse mag if u want so its top left and bottom right cylinder. Ol John T in Indiana
AL
01-19-2000 09:55:27
there's more to it than that. You've not yet timed it, you've only installed it!
george
01-19-2000 15:48:39
 Re: Re: John Deere Model A Timing in reply to AL, 01-19-2000 09:55:27
So then all you needto do is adjust the mag so that the impulse clicks at the timing mark on flywheel and trasnsmission case cover. pretty simple..... .....
george
01-19-2000 06:58:30
Just install the mag and hook up the wires, if it backfires or won't start, remove the mag, turn the drive lug 180 degrees and reinstall. A mag can only be installed two ways. The right way, or 180 degrees off.
