Anyone's 1020 Run Hot or Is that Normal?
lekander883
07-23-2007 18:11:24
A new tractor for me so I'm trying to figure her out. The temp gauge runs real close to the hot line. It doesnt ever reach the line but not far from it. Also when I lift the radiator cap I never see fluid. I'll fill her up but when its warmed up she'll spit it out the over flow. Anyone else have the same situation.
buickanddeere
07-24-2007 12:40:50
 Re: Anyone's 1020 Run Hot or Is that Normal? in reply to lekander883, 07-23-2007 18:11:24
Test the temp sender by suspending it in a pot of water with a candy thermometer. Don't let the probe/thermometer touch bottom or the sides. 195F is a good temp for fuel efficiency, less engine wear and cleaner exhaust. The rads in many tractors are mounted out of plain sight and get plugged with oily dirt. Use low pressure water or the fins will get bent.
TomIN
07-24-2007 08:05:57
I bought a gas 301A industrial version of the 1020 last year. It ran very hot. Cleaning the radiator, replacing the thermostat, hoses, and antifreeze didn't help much. I eventually checked the timing. It was severly retarded (but the tractor ran well). Advancing the timing to factory specs seems to have cured the overheating.
Ten-Twenty
07-24-2007 06:14:35
Troy,
The 1020 is a MUCH improved design over the 1010 so don't start second guessing your decision to buy a 1020.
Mike M
07-24-2007 06:11:31
It may not seem like it now , but you will be better off with the 1020 than the 1010 after you get it straightened out.
Those have no overflow tank so if you fill them clear up it will blow some out. Usually down a few inches below a baffle in there so it's hard to spot. If you do think the head gasket is blown ? if you get ahold of a coolant system pressure tester and put it on the rad. then crank it over or maybe even start it and watch to see if it builds really fast ! watch you don't blow the rad. if it is building up pressure fast. You can also fill it full and leave the cap off and watch for bubbles but it's hard to tell sometimes ? Check that thermostat out too as it may have one stuck closed or really high temp. Engine shut off ! grab a fan blade and try to wiggle the water pump shaft about any wiggle and it is bad. They can be real bad and still not leak.
Tx Jim
07-24-2007 05:49:19
 Re: Never run hot Re: Anyone's 1020 Run Hot or Is that Norma in reply to JOE-ILLINOIS, 07-23-2007 18:11:24
Troy the head gasket is located under the cylinder head and just above the engine block. On loosing water,it could be faulty radiator cap or compression causing more PSI than rad. cap is designed for. Tx Jim
cowman1
07-23-2007 22:28:59
 Never run hot Re: Anyone's 1020 Run Hot or Is that Normal? in reply to lekander883, 07-23-2007 18:11:24
You dont say if it is a gas or diesel. But I had a gasser it didnt run hot even when the radiator was covered solid with chaff pulling a 7ft brush hog hard! Sounds like a leaky head gasket to me. Those are all the symptoms. But I would check the cooling system over first.
lekander883
07-24-2007 03:31:07
 Re: Never run hot Re: Anyone's 1020 Run Hot or Is that Norma in reply to cowman1, 07-23-2007 22:28:59
Where's the head gasket located at? It's a gasser. Troy
Roy in georgia
07-23-2007 18:54:23
I have a 1010 and not sure about the differences on the 1010 and 1020 but mine ran hot too.I took the screen off the front and found that the grease and oil from the steering box had run down the front causing the radiator to be clogged with dirt so blowing air in it to get the built up debris out didn't work, also in the summer you really need a thermostat to let the water stay in the radiator long enough to cool so I would see if someone took it out or if it is sticking open. One more thought is the lower radiator hose could be sucking in causing restriction. hope it helps, Roy
lekander883
07-23-2007 19:26:42
 Re: Anyone's 1020 Run Hot or Is that Normal? in reply to Roy in georgia, 07-23-2007 18:54:23
I also removed both side screen's, and blew out the radiator. I'll check tomarrow to see if there's a thermostat. If its been removed, its possible that it ran hotter with one? Most replies I get are from onwners of the 1010 The auction I bought my 1020 from also had a 1010 with a loader brand new tires everything else looked a little rough but It ran real nice. $3800 I bought the 1020 for $7000
Mike M
07-24-2007 11:04:29
 Re: Anyone's 1020 Run Hot or Is that Normal? in reply to lekander883, 07-23-2007 19:26:42
I hope you got a loader too.
