4020 tachometer
Nellie 47
07-23-2007 18:09:44
Have a 1965 and 1967 4020. Been looking for replacement tachs. Can't seem to find any thing that looks like the original. If anyone could give me an idea where to get one repaired or buy a replacement it would be appeciated. One has some moisture behind the glass and the hour meter does not work on the other. They look good for the age of them. How big of a deal is it to tear one apart to clean the moisture up? Any ideas would be helpful. One is a power shift and one a syncro.
zwr
07-23-2007 20:10:01
 Re: 4020 tachometer in reply to Nellie 47, 07-23-2007 18:09:44
I never had a tach out but I've dealt with similar instruments that had moisture condensed behing the glass. Remove the piece to a low humididy area. Use a hair dryer against the lens and otherwise to drive the moisture out. Look for cracks you can then seal up with Permatex or Silicone.
On the other one, if you can get into it w/o destroying it you will probably find something amiss that you can repair yourself. The co-axial drive cable drives a drum/magnet arrangement against a spiral spring to get the rpm pointer, but uses a direct drive, probably a worm pinion, to drive the odometer.
Good luck!
