1945 JD Model B
Terrence
07-23-2007 15:51:50
While running my B the other day,I noticed that i can hardly move my throttle without the engine revving way up,she'll idle fine,hand crank startsgreat-but as soon as i just bump the throttle up,it seems to race up-should I look at gov. or carb ? Thanks for your input.
greenmech
07-23-2007 20:19:11
 Re: 1945 JD Model B in reply to Terrence, 07-23-2007 15:51:50
To me it sounds like your governor weights are stuck and not letting it throttle down.I would check movement of the weights or sliding shaft.Ron Mn.
almrm
07-24-2007 07:34:47
 Re: 1945 JD Model B in reply to greenmech, 07-23-2007 20:19:11
GM
I am not getting good governor performance on my 35 A either. The linkages are set right per P. Browing's perscription but I am getting little or no governor assistance controlling the engine speed. I throttle up to go up hill and back to go downhill. All I have is hills. On loads it is smoother. I peeked behind the cover and the weights are there and swing freely. I did not check the sliding shaft. Thanks for the tip, I think this might be my problem.
Terrence,
If you look behind the cover, Make sure you remove the mag. If you don"t you will likely break the mag flange when you reassemble. If you take the governor assembly out or out a little bit, make sure you can read the registration marks on the cam and governor gear or mark them so you can so you reassemble correctly. Roll the engine so the cam gear registration is on the top before disassembly. My aplopgies if you already know these precautions, but there have been a lot of costly mistakes made in this area.
Regards,
Mark
P Browning
07-23-2007 16:35:18
Terrance -- I like to check out the simple, easy-to-do things first, and the main thing to verify (first) is the linkage adjust between governor and carburetor throttle. See below an excerpt from a restoration manaul dealing with this issue. (PatB)
LINKAGE ADJUSTMENT -- Free up and align all linkage to remove any binding. Adjust or renew any parts causing lost motion, and disconnect throttle rod at carburetor.
With hand control in full speed position (engine not running), adjust the length of the carburetor throttle rod so that the rod is 1/2 hole short from entering hole in carburetor throttle shaft lever when carburetor butterfly is in wide open position. Reconnect throttle rod at carburetor.
johndeereman
07-23-2007 16:15:03
sounds like mabe you need the spring plate thing a ma bob it goes between the throttle and the governer its a thin flat piece of steel that is springy dont know how else to describe it
teddy52food
07-23-2007 20:54:05
 Re: 1945 JD Model B in reply to johndeereman, 07-23-2007 16:15:03
That would be the governor spring. The spring opens the throttle, the flyweights close it. I think you have a problem with the weights. Or the thrust bearing.
