430w final drives
Richard Chishol
07-23-2007 07:26:34
I have a 1960 430W on which someone has cut the axles. The easiestw ay of replacing them is to replace the entire final drive(s). Does anyone know if final drives off an early 1010 will fit They look the same.
buickanddeere
07-24-2007 13:10:36
 Re: 430w final drives in reply to Richard Chisholm, 07-23-2007 07:26:34
The 1010 axles and post 125,001 serial # 420, 430, 440, 435 final reduction drives. They will swap. The late 31,001 1010 finals offer a higher ratio/slower speeds than the pre 31,000 1010 finals. A benefit as the reverse in those 430's etc is plenty fast. The drawbar mounts onto the finals different on a 1010 than on a 420/430/435/440.
Richard Chisholm
07-24-2007 13:26:25
 Re: 430w final drives in reply to buickanddeere, 07-24-2007 13:10:36
Hi BuickandDeere
Many thanks for this. I had read about it somewhere but could not find the specific information. Only problem is the drawbar mounts which would make the 430W non original. Are the differences major? Do teh differ between pre 31000 1010s and post 31000?
Regards
Richard
