JD H Runs good starts hard.update
JOE
01-18-2000 16:37:44
About a week ago I posted about my tractor not starting good. I reseaved a lot of help and check everything suggested. When I borrowed a mag from a freind the tractor started up very easy. I tryed it several times and the outcome was the same. I think this has fixed my problem. Thanks to all who replyed.My mag has been returned for repair, they think the coil is bad. The spark from both mags looks the same to me but the tractor will only start by hand with the borrowed mag. I am looking to buy a 430 but dont know much about them. Is there enything I should look out for. Your suggestion are welcome
clooney
01-18-2000 19:16:59
 Re: JD H Runs good starts hard.update in reply to JOE, 01-18-2000 16:37:44
Joe, look at the block behind the carb. for freeze cracks. Also check the radiator for leaks & cracks,if its a standard or utility,take a look at the rear wheels for rusting through around the valve stem holes & the mounting holes for elongation ( the rear wheels are getting hard to come by for those tractors),see if the shaft coming out of the govenor has a lot of play in it (they tend to wear in that area),also get it good & warm & see if the engine oil pressure stays up. Then drive it & listen for transmission noises(some are normal) real loud or noisy in low gears isn't.If possible take sombody that is familar 40-420-430's with you when you look at it. Also read all the posts you can find on the 420-430 to see what other problems people are having with them.
