JD 1020 Getting gas, has Spark, wont run?
lekander883
07-22-2007 18:49:07
John Deere 1020 Gasser Was running smooth for a few hours on a project. All of a sudden she starts to sputter out. First I filled her full of gas and nothing. Than I check for spark. Sparking on all three. Hit the key and nothing. I Looked at the carb and I saw her dripping gas. So than I waited about an hour and tried the key and nothing. What gives. What could it be. Dont tell me I've got bigger problems than that do I?
Loren NC
07-23-2007 08:50:26
 Re: JD 1020 Getting gas, has Spark, wont run? in reply to lekander883, 07-22-2007 18:49:07
Don't know about your 1020 but my 1010 has an internal fuel screen in the carb. Pull the fitting out where the gas line connects to the carb and take a look at it. Mine was completely full of fuzz and did exactly what you are describing that yours does. You can pick and blow the fuzz out if you are careful.
lekander883
07-23-2007 16:27:55
 Re: JD 1020 Getting gas, has Spark, wont run? in reply to Loren NC, 07-23-2007 08:50:26
Thanks for your help. I cleaned the filter out and removed the air cleaner hose and gas poured from the carb. After cranking her over a little she blew black smoke and was running again. What a great feeling!
pawel
07-22-2007 18:56:53
No big problem if it was running before, it's only flooded
maybe a small prob in carburetor like dirt in the line or blocked jet something like that
drain the carb and see if its working right, if you have to spin the carb off and take a peak to see whats up with it
lekander883
07-23-2007 03:39:16
 Re: JD 1020 Getting gas, has Spark, wont run? in reply to pawel, 07-22-2007 18:56:53
I let her be for the night, and tried her again this morning. Ran for about a second and died. Im not very knowledgable on carburators. Any help as to where the filter is. Also how to drain the carb? All info appreciated. Troy
