4010 minimum brake pad thickness?
TimS in Mo
07-22-2007 17:50:38
I pulled the right rear axle on one of our 4010s to replace the bolt that the triangular plate holds still as it was starting to seep some oil....
I figured while I had it off, I would replace brake pads if needed ( the other 4010 needs brake pads, fun fun, more axles to pull ).
Any idea what the minimum thickness is? These are just about down to the rivet heads.
G/MAN
07-23-2007 13:42:46
 Re: 4010 minimum brake pad thickness? in reply to TimS in Mo, 07-22-2007 17:50:38
If you're getting oil leakage past the inner seal and eventually out past the outer seal, the final-drives should be disassembled and the inner seals replaced, along with the outer seal and seal spacer, and the bearings should be inspected and replaced if necessary. Tightening the bolt probably won't repair the leak, and while you're there, it's worth doing them right. Along with the brakes - new facings on the pistons and plates, new o-rings and backup rings in the piston bores, check the disks for flatness and wear, etc. Normally on an older tractor, the brake pads will be loose on the piston plates and backing plates even if they're not completely worn down.
ET
07-23-2007 04:48:54
While you are in there do the brakes. It's cheap insurance. As you said about the other 4010 that needs brakes fun, fun, fun.
Mike Aylward
07-22-2007 21:06:54
Tim, it will pay you to talk to the service manager at your local dealer. The procedure to tighten the big bolt has changed since the service manuals were printed. You now use lead balls and torque the bolt to a certain amount and then remove the balls, measure their thickness with a micrometer, and install shims so the bolt can actually be tightened against something. G/Man or someone else can give you those torque readings and the procedure as I am doing it off of memory and am not sure enough to quote it here. Mike
TimS in Mo
07-22-2007 22:31:58
 Re: 4010 minimum brake pad thickness? in reply to Mike Aylward, 07-22-2007 21:06:54
I had talked to the service manager about that procedure...he mentioned using the lead ball and shims on some of the newer model tractors, but he didn't specify I could use it on the 4010...I will call and check in the morning.
61-4010
07-22-2007 19:56:18
Howdy. While you have the axle off, I would do them if down to the rivet heads. Expect this to not be cheap.....just did my 4010 a couple months ago and it was 20 or 30 bucks a pad - - and there are 6 per side.
Also keep this in mind....as I learned this the hard way. When you get new pads, don't expect something real "thick." I put my pads on and was quite disappointed thinking they were going to be thick like an auto pad. Hopefully because they are in oil they will last a LONNNGGG time.
bobmnl
07-22-2007 20:25:13
 Re: 4010 minimum brake pad thickness? in reply to 61-4010, 07-22-2007 19:56:18
pads should last 5-7k hrs depending on usage since they're oil bath
